My new 2CV, running restoration. In theory..
Little Louis
 Re: My new 2CV, running restoration. In theory..
Have fun with the Monroes
| March 23rd, 2015, 9:31 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
@LittleLouis
Need new shocks, what should I purchase. ECAS standard offeringds, are Monroes
| March 24th, 2015, 9:42 am |
panelbeaterpeter
Joined: April 24th, 2011, 6:05 pm Posts: 226 Location: Everywhere
The wear to those knife edges is almost unbelievable! I replaced them as my originals were damaged. My new ones don't have those rough milling marks so fingers crossed they're not the same. I'll keep an eye on them and in the meantime try to find some originals. I think maybe 2 of my old ones are ok.
Louis, please elaborate on your comment..
_________________ (°\=/°)
| March 24th, 2015, 11:30 pm |
Peter, looks as though the fellow with the tub of grease and a paintbrush in the Mangualde factory was in a good mood the day your rolling chassis was put together, as there's a bit more grease around the bearings than many I've seen. Still not as much as I put on them, since I hate changing (rear) axle bearings with the body attached to the chassis. A couple of passing comments, albeit a bit late in the day... It's not necessary to disconnect the track rods in order to remove the front arms from the axle, moving the steering rack towards the side that you're working on will give enough slack to ease the arm outwards, inspect the bearing and slap some grease on it if required.  Regarding the nuts securing the dampers, they shouldn't be torqued up until the car is built up and sitting on its wheels at the correct ride height, so that the rubber bushes in the damper eyes are in their 'neutral' position. This applies mostly to the ends of the dampers nearest to the suspension arms, since they have the largest arc of movement, less for the inner ends.
| March 25th, 2015, 1:01 am |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
Pete, AFAIK Monroes are the best available for a road car these days since the Lip production ceased (sad days). I put a full set on the Mehari I rebuilt for my dad and it ran fine. My acad had a full set of monroes for years and ran fine too.
Any shock is better than no shock.
| March 25th, 2015, 1:17 pm |
subarupete
@smyth602 Ta
| March 25th, 2015, 1:55 pm |
Martyn, guess you haven't tried KYB dampers yet? They really are 'shocking'... smyth602 wrote: Any shock is better than no shock.
| March 25th, 2015, 3:33 pm |
smyth602
Haggis Muncher
I guess there's an exception for every rule  On a happy note though, Ken - look what i found attached to the donor acad i just picked up    The one i pulled off even seems to be in some manner of working order!
| March 25th, 2015, 3:46 pm |
Nice one. A word of advice. Don't compress them until you've removed the plastic cover sleeves to check for any pitting or other corrosion damage on the exposed sections of the pushrods. ( About 1/8 turn of the sleeve relative to its mounting should unclip it, then it can be pulled clear over the damper body.) It only takes one or two passes through the end seal of a rusted rod to damage the seal and a leak to start... That's why I keep the exposed sections of the rods greased.
| March 25th, 2015, 5:37 pm |
Phoaarr look at the length of that!
| March 25th, 2015, 6:08 pm |
Users browsing this forum: No registered users and 523 guests |
