View unanswered posts | View active topics It is currently May 7th, 2026, 5:39 pm
Reply to topic  [ 182 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 19  Next
 Early Ami
Post Re: Early Ami
This was a plesant surprise though
All solid and mostly shiney under there
September 29th, 2012, 9:50 pm
Post Re: Early Ami
It is a beauty :D , with a lot of work ! ;)
September 29th, 2012, 9:53 pm
Post Re: Early Ami
Bonnet has seen better days
Last edited by Mr Unhinged on September 29th, 2012, 10:04 pm, edited 2 times in total.
September 29th, 2012, 9:57 pm
Post Re: Early Ami
Good luck fella, and 100% worth saving.. :D
Be an interesting one to watch of the coming months and dare I say it......years ;)
Dyane 12 1976 (ish)
September 29th, 2012, 10:01 pm
Post Re: Early Ami
Make no mistake this is going to take a bit more than a few weekends , This is big and scary stuff, but thanks :D.
I think I will be visiting this support group quite a bit in the coming months.
My name is Mark and I have a Welding habit :lol:
September 29th, 2012, 10:11 pm
Post Re: Early Ami
I thoUght you said wedding habit at first glance!!
September 29th, 2012, 10:54 pm
Post Re: Early Ami
Once is enough :D
September 29th, 2012, 11:31 pm
Post Re: Early Ami
Is fourth gear actually missing or are you trying to get to it from neutral? On certain old gearboxes, yours included I think, you can only get to fourth from third gear. When in third, push the stick to the right and forward, unlike your late 2cv where you'd push it forward into neutral then right and forward into fourth. It's hard to describe, but check out the gearshift pattern on the dash of your D*lly and then compare it to the one on the dash of an old ripple or similar. You can only get it out of fourth through third gear.
September 30th, 2012, 12:03 am
Post Re: Early Ami
Ah right , that may well be the case then, There is a resistance like its not in the gate so it would make sense i was wiggling in the wrong place.
Edit: I was wiggling in the wrong place its 4th from third by going over and in...Duh! I have much to learn :lol:
Sounds odd but Washing the Moss off this afternoon was a pleasant experience.
Any idea who is good for Repro floor and Sill panels on these things Russ?
Or am I better off getting some Steel Stock and going from there?
September 30th, 2012, 12:15 am
Post Re: Early Ami
Try Daniel Englhardt www.franzoesiche-klassiker-shop.de.
September 30th, 2012, 8:49 am
