Author |
2cvkeza
Joined: February 11th, 2010, 11:36 am Posts: 603 Location: Slovenia
 Re: My work...
This is smallest 2cv garage in the world... 2,5 meters X 5,0 meters , And 2,3 meters high .
_________________ www.2cvkeza.com
December 6th, 2010, 5:19 pm |
EirikJ
 Re: My work...
Maybe this is something to think about? This small transportable scissor-lift will fit in you're garage:    Width: 100 - 140 cm Length: 75 - 200 cm Dimensions are the distance between adjustable lifting arms, I think. It doesnt lift high(100cm), but then again, you're garage has it's limits anyway. The point being to get the wheels of the ground, fast and easy. It weights 360 kg and can lift 2700kg. No bolting to the floor, can move it around and no requirements to the concrete, as with normal bolted-to-the-floor lifts. Should work well with A-models. A friend of mine has one like this in his garage, for the work on his DS.
December 6th, 2010, 8:16 pm |
EirikJ
 Re: My work...
Oh, I forgot: As always, beautiful work on the Dyane
December 6th, 2010, 8:17 pm |
2cvkeza
 Re: My work...
Thanks...
Next spring I will make some small garage outside on front yard and I will have some lift inside. Again like my garage also my front yard is small.
December 6th, 2010, 8:22 pm |
Erasmo
 Re: My work...
EirikJ wrote: Maybe this is something to think about? This small transportable scissor-lift will fit in you're garage:    Width: 100 - 140 cm Length: 75 - 200 cm Dimensions are the distance between adjustable lifting arms, I think. It doesnt lift high(100cm), but then again, you're garage has it's limits anyway. The point being to get the wheels of the ground, fast and easy. It weights 360 kg and can lift 2700kg. No bolting to the floor, can move it around and no requirements to the concrete, as with normal bolted-to-the-floor lifts. Should work well with A-models. A friend of mine has one like this in his garage, for the work on his DS. That was indeed the idea I had in mind. 2cvkeza wrote: Thanks...
Next spring I will make some small garage outside on front yard and I will have some lift inside. Again like my garage also my front yard is small. Are you going to build a new one or are you going to expand the current garage?
December 7th, 2010, 12:52 am |
2cvkeza
 Re: My work...
Probably new one. But like I said, there is not much space available.
December 7th, 2010, 7:04 am |
2cvkeza
 NEW WEB SITE...
I am working on my new web site. I will include also English version... My history,my work, history of clubs, travels, history of Tomos and Cimos cars with original brochures from that period and a lot more check this ... http://2cvkeza.weebly.comLatter it will work normaly on my domain www.2cvkeza.com
December 15th, 2010, 11:43 am |
Old-Nail
 Re: My work...
Dyane is better than new, fantastic work.
December 15th, 2010, 1:31 pm |
2cvkeza
 Re: My work...
December 23rd, 2010, 8:21 am |
2cvkeza
 Re: My work...
December 23rd, 2010, 8:41 am |
Users browsing this forum: No registered users and 15 guests |
