samfieldhouse
 Re: Our family's 1985 Mehari
  'nuff said.
| November 25th, 2012, 5:37 pm |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
There's time i wish this place had a 'like' button...
| November 25th, 2012, 7:16 pm |
Russell
How's the D*lly looking?
| November 25th, 2012, 8:06 pm |
evilben
Joined: October 28th, 2011, 5:40 pm Posts: 328 Location: Cornwall
I checked out the new Mehari body shell at the NEC last weekend are they really that thin and wobbly? or do they normally have an inner frame..
I kept coming back to the 2CV GB stand and checking out the Ami 6 and the early Dyane ( loved it ) and the black Pallas near by...
_________________ www.evilbens.blogspot.com
| November 25th, 2012, 9:23 pm |
samfieldhouse
Meharis have a subframe that bolts to the chassis. The bodywork is actually pretty solid. No comment on the one at the NEC
| November 25th, 2012, 9:31 pm |
toomany2cvs
evilben wrote: I checked out the new Mehari body shell at the NEC last weekend are they really that thin and wobbly? The tupperware is, yep. Quote: or do they normally have an inner frame.. "Mostly" is probably the right answer there. Or maybe "originally".
| November 25th, 2012, 9:55 pm |
Rjsmart
The Cassis Mehari body is produced from the original moulds and when the plastic is moulded the panel design with ridges etc add strength and when pop riveted to the tube framework the structure is pretty solid but can flex. The design is clever using material properties to great effect. I replaced my dashboard section with a new section which had split and the finished result is as the original Regards Richard
| November 27th, 2012, 10:48 pm |
Jonathan
Joined: January 1st, 2009, 7:37 pm Posts: 4713 Location: Disunited Kingdom
Rjsmart wrote: I replaced my dashboard section with a new section which had split and the finished result is as the original Split?
| November 27th, 2012, 11:41 pm |
Umm, the original panels were ABS, which is quite tough stuff. The *replacement panels from Cassis* are fibreglass, but as it's only the same thickness as the ABS originals, it certainly isn't tough. I fitted a Cassis bonnet with spare wheel well onto a Mehari heading for Raid Iceland this year and had to add a steel bar across the engine bay so that it could actually support the spare wheel. The disc which covers the centre of the spare wheel was so flimsy that the owner had to remove it when travelling at a reasonable speed on the open road... ken edit/ *Those I've seen are fibreglass, perhaps they use the correct material for others? * toomany2cvs wrote: The tupperware is, yep.
| November 28th, 2012, 12:40 am |
deuchebleu
They appear to do two, ABS/ASA and ABS/PPMA, both using the original moulds but the former, they say, is original quality ABS and is quite a bit more expensive. John
| November 28th, 2012, 12:59 am |
