View unanswered posts | View active topics It is currently May 7th, 2026, 10:37 am
Reply to topic  [ 311 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32  Next
 1979 Jaune Mimosa 2CV
It's not the floor I want to do, at least, I would do but I can't justify the cost. I want to tile the walls around the bench in black and white chequers. When cleaning the engine I flicked some specks of grease on the wall and I want to be able to wipe it off quickly and cleanly, with the brickwork it tends to smear in and doesn't come off easily. I wanted to tile it but wondered if there's a grout which doesn't look filthy straight away.
January 1st, 2015, 2:03 pm
And suddenly it makes sense, clever idea..
What about a sheet of stainless, or sealed ply on the wall? (Not trying to talk you out of tiling, i like the idea but i like quick ideas more)
January 1st, 2015, 4:50 pm
I put up sheets of wood - but I like the stainless idea too, maybe with a cushion sheet behind.
January 1st, 2015, 5:06 pm
A stainless or galvanised splashback would be good. Failing that, how about a bit of your floor paint on the wall?
January 1st, 2015, 5:33 pm
Perfect - use a good grey cement grout no problems
January 1st, 2015, 6:21 pm
I have window glass behind the kitchensink at the wall, it is very easy to clean... however throwing a engine at the glass wouldn't be a good idea..
But I think (stainless) steel is easier to obtain for you anyway...
January 1st, 2015, 7:06 pm
Stainless would be great, but have you seen the cost of it?
January 1st, 2015, 7:19 pm
I have. My bench is stainless but like everything else I didn't pay for it. I don't think there's any more behind the metal rack at work (where I find many things which need reappropriating). I wanted something a little 'warmer' than metal, I want 'clean' without looking like a butchers shop (whilst I can see an irony there). Tiling it seemed to be the most pleasant solution. If that grout will wipe clean reasonably easily I'll have a stab at it. I've only tiled a kitchen before and I didn't enjoy it but maybe being a little more experienced I might do better this time.
When are ecas open again?
January 1st, 2015, 11:35 pm
5th.
Looks like a busy return for Roy...
January 1st, 2015, 11:42 pm
I know stainless would be expensive, but you could use 306 stainless as apposed to 316 which would reduce the cost somewhat
Do post some pics of it tiled btw!!
January 2nd, 2015, 1:13 am
Users browsing this forum: No registered users and 285 guests
