Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1661 Location: Exeter, Devon
 Re: Yellow Dyane
I have same setup on the Shed, and it looks ok
| June 2nd, 2022, 9:15 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 898 Location: Rhayader Mid Wales
 Re: Yellow Dyane
P1030761 by Robndaisy, on Flickr I used the old air filter to carb hose which,with some persuasion, I managed to fit without too much swearing  . Just need to trim the end of the hoseclip. AZL57 wrote: Very nice. Are you able to put the hose between the cowling an the filter? Looks like there it's a bit to close??
| June 3rd, 2022, 12:32 pm |
rob massey55
 Re: Yellow Dyane
I still need to paint the bracket that holds the throttle spring  . Roger V wrote: I have same setup on the Shed, and it looks ok
| June 3rd, 2022, 12:33 pm |
rob massey55
 Re: Yellow Dyane
This late Dyane has plastic headlamp bowls, there are nuts set into the back of it, rusty nuts that would never unscrew without turning in the moulding. I cut off the heads with a slitting disc and then punched out the nuts when the unit was on the bench. P1030746 by Robndaisy, on Flickr The headlamp clicks into three plastic/nylon? sockets and adjustment is by moving the ballscrews fastened to the lamp in and out for alignment. one of the sockets is connected by a long cable to the control knob in the cabin that sets the lights depending on how loaded the car is. The cables are seized just at the ends where they meet the headlamp bowl, I might see if I can shorten them, otherwise it's new ones I guess. P1030747 by Robndaisy, on Flickr P1030754 by Robndaisy, on Flickr P1030748 by Robndaisy, on Flickr As you can see, it's lost one of it's lugs and the rusty cable end has bailed out. It's got to be replaced and luckily, repro kits are available. It's spring loaded and happy where it is. P1030755 by Robndaisy, on Flickr I pushed it back, P1030756 by Robndaisy, on Flickr P1030757 by Robndaisy, on Flickr got the cutters on it and cut it. The spring shot out but I managed to find it, a minor miracle in this mess of a shed  . P1030758 by Robndaisy, on Flickr P1030753 by Robndaisy, on Flickr P1030751 by Robndaisy, on Flickr The fixed sockets that were broken I drilled a 5mm. hole in them a little way and punched them out.
| June 3rd, 2022, 1:45 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2278 Location: South-Limburg
 Re: Yellow Dyane
Nice job...
| June 3rd, 2022, 8:21 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 421 Location: Greece
 Re: Yellow Dyane
I salute your relentless efforts. A great encouragement to us all.
| June 3rd, 2022, 9:54 pm |
rob massey55
 Re: Yellow Dyane
P1030762 by Robndaisy, on Flickr The left wing had battery acid corrosion and was very thin. P1030765 by Robndaisy, on Flickr Managed to stitch it, better than fresh air. P1030769 by Robndaisy, on Flickr Rough but the seam sealer will help. P1030766 by Robndaisy, on Flickr Yes I've still got the paint that I used on the van. P1030773 by Robndaisy, on Flickr That's just about the distance so it looks ok  . Ford Rio Brown is a passable colour. The inner wings are factory primered brown and I guess that's how they were?
| June 19th, 2022, 9:33 pm |
rob massey55
 Re: Yellow Dyane
I went over to ECAS and picked up tyres, rims headlights etc. and also the cables to move the lamps when the car is loaded. P1030778 by Robndaisy, on Flickr This is to support the new sliding socket as I press the end of the cable home, don't want to mess up now. P1030776 by Robndaisy, on Flickr It went in after I'd made the crimped end acceptable  I get that the Dyane is a better car but there are things that compared to the brutal simplicity of earlier A series, are just more opportunities to rust or break. Still the flamer is 40 years old and nearly done
| June 27th, 2022, 7:40 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
 Re: Yellow Dyane
Hats off the your ingenuity and tenacity.
| June 27th, 2022, 9:35 pm |
rob massey55
 Re: Yellow Dyane
Thanks Pete, I've project fatigue big time now though, I just want the flamer all together and back on the road. I think it's a combination of working 5 days 'cos my boss left and we've been unable to find a suitable replacement and a general sense of old age catching up with me  .
| June 28th, 2022, 8:22 am |
Users browsing this forum: No registered users and 461 guests |
