View unanswered posts | View active topics It is currently August 14th, 2025, 6:15 pm
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 78  Next
 Van repairs
Post Re: Van repairs
It's largely exagarated. It is written in all 2cv books. I wonder if one author once had a 2cv in test with not right mounted driveshafts? And every one esle copied this story..Forks should be on the same plane otherwise they will jerk.
February 6th, 2018, 7:18 pm
Like this then?
ImageP1010605 by Robndaisy, on Flickr
February 6th, 2018, 7:58 pm
Yes exact right... ;-)
Only bit of jerking at full turn when the car has to work heavy. Like a steep uphill sharp turn. For the rest not much different like another car..
February 6th, 2018, 8:56 pm
Bedankt.
February 6th, 2018, 9:16 pm
time to put the differential hub unit back together with new seals 'cos they were leaking when i stripped 'em back in 2014.
ImageP1010608 by Robndaisy, on Flickr
ImageP1010606 by Robndaisy, on Flickr
ImageP1010607 by Robndaisy, on Flickr
Had made something to undo the bushnut, found it under the bench at the back with the spiders and the mice.
ImageP1010612 by Robndaisy, on Flickr
Cleaned up the yoke for the UJ cup(because it was damaged) and partially fitted it before pressing in the shaft. Remembered to fit the brake backplate first.
ImageP1010614 by Robndaisy, on Flickr
Should have used new bearings though :roll: After trial tightening there's sideways play in the bearing so it's got to come out...somehow :) .
February 10th, 2018, 9:47 pm
You better replaced the bearings before putting it all together.
I don't understand why you did not replace them anyway, just in case ...
February 10th, 2018, 11:08 pm
A momentary lapse of reason :roll: :oops: :mrgreen: .
February 11th, 2018, 12:53 am
New bearing fitted, on to the universal joint.
ImageP1010615 by Robndaisy, on Flickr
ImageP1010616 by Robndaisy, on Flickr
ImageP1010617 by Robndaisy, on Flickr
ImageP1010618 by Robndaisy, on Flickr
February 15th, 2018, 12:37 am
Looking at the last picture(s) anyone from the Landrover forum would think you are doing a prop shaft..
Lovely "touchable" technics on a old 2cv..
February 15th, 2018, 7:28 am
Got two cups installed OK on the other shaft and then ran into trouble.
ImageP1010622 by Robndaisy, on Flickr
The cups kept misaligning and pushing the needles out of line. It took all day to get the flamer in, still the beer was nice afterwards!
Today was much easier.
ImageP1010629 by Robndaisy, on Flickr
New gaskets,
ImageP1010630 by Robndaisy, on Flickr
Making sure the adjusters are free and lubricated.
ImageP1010631 by Robndaisy, on Flickr
ImageP1010632 by Robndaisy, on Flickr
Flaming Weekend went too fast :) .
February 18th, 2018, 7:12 pm
Users browsing this forum: No registered users and 17 guests
