View unanswered posts | View active topics It is currently February 3rd, 2026, 6:38 pm
Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24
 Belinda: on the road
Post Re: Belinda: on the road
I didn't have chance to post these pics before the National so here goes:
I've been doing a bit more of the bodywork every so often & have been putting off replacing a piece of wood that's been delaminating under the driver's door sill.
As with all the panels that I think about replacing, I sand away the paint to reveal where the rivets are that hold the panels on first. Seeing as there were only 3 rivets holding this piece on to the main internal longitudinal box section and the wood panel is only superficial, I decided that I could remove it & tidy up the metal behind without having to replace the wood in one go.
This is what I found underneath, just surface rust & easily tidied up.
A generous helping of red oxide primer and the area will be ready to accept some new wood next week.
August 30th, 2010, 4:14 pm
Ive got some spare laminated wood flooring in the shed if you fancy covering the whole car? :lol: not sure about how well it would stand up to rain though!
August 30th, 2010, 7:36 pm
Ah well cleverclogs, remember - it's not what you use, it's how you cover it. You wouldn't weld in new metal in & just leave it would you? :roll:
August 31st, 2010, 3:12 am
Here's a quick post to mention what I thought was going to be a tricky repair but wasn't.
I'd previously wire brushed a rusty area below the windscreen but had recently noticed rust coming back through the paint so I decided a bit more digging was required. After sanding back a bigger area with a flapper disc on my angle grinder, 2 holes appeared so I cut a squarer hole round them to make it easier for welding.
This is the resulting hole
and the repaired area
September 11th, 2010, 2:39 pm
Well I'm ashamed to admit that I haven't given Belinda much attention over the winter apart from starting her a couple of times but today I've given her a run in preparation for Firkin Freezing next weekend. It took a bit of cranking & a bit of petrol in the carb but we got there in the end.
I've taken her for a couple of trips out over the weekend & was brave enough to try a 6am trip to work this morning. The frost on the windscreen was surprisingly quick to demist (yes, DEMIST!!!) but the cabin is still a bit chilly due to draughts getting in around the roof. Although Mehari owners will produce the smallest violin in the world at this point, I may spend the next couple of weeks running some draught excluder around the base of the detachable roof & revisiting the idea of sound proofing (and therefore insulating) the bulkhead.
January 31st, 2011, 11:35 am
Users browsing this forum: No registered users and 236 guests
