View unanswered posts | View active topics It is currently May 8th, 2026, 1:00 am
Reply to topic  [ 438 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 44  Next
 1988 2cv D*lly bits and bobs
Post Re: 1988 2cv D*lly bits and bobs
It's defiantly not too high. I'll check anyway tomorrow
September 12th, 2011, 9:48 pm
so my battery is under charging, need to play with the reg, i put my battery on charge the other night after a run and it was drawing 3-4 amps of the charger,
woops, will sort that out soon,
any how forgetting things i need to do, one evening when i was boored i decided to G3 one of the wings at work,
this is the RHS wing, (i decided to take photos after G3'ing the wing to make a before and after impossible :roll: ) but this is the rhs (as left hand was before)
after a spot of G3 and a buffer
few other shots whilst i was playing with a camera
going to try and fire the dyane engine up on monday with chris :D
September 17th, 2011, 11:17 pm
Nice front Grille, where did you get that from??
September 19th, 2011, 9:48 am
Ecas. 39 quid ;)
September 19th, 2011, 12:18 pm
Fan flew off this morning, luckily it didnt smash the oil cooler or anything else, but it did hit the stone gaurd behind the grill, and it smashed to pieces,
no idea where half the blades went, but luckily I had a spare on the shelf!
September 20th, 2011, 1:48 pm
Fans break but they don't normally come off! Had you not tightened it up properly? Are you using a lock washer? Stop fannying around setting your points every weekend and it'll stay put!
September 20th, 2011, 1:59 pm
Have you not got any mesh behind the grille?
September 20th, 2011, 2:04 pm
I had a fan come off whilst driving, but found that was due to the bolt not being tightened up correctly!! Luckily no damage.
September 20th, 2011, 3:39 pm
i dont fanny about and do the points every weekend :? :?
I do them when they need doing.. As most things... :S
id borrowed the bolt out of it to turn the dyane engine over and forgot to put it back..
and no I lost the bolts, and russ gave me some and i never got around to putting the guard back on!
September 20th, 2011, 4:25 pm
Wish you lot would stop talking about fanny
September 20th, 2011, 6:49 pm
Users browsing this forum: No registered users and 96 guests
