View unanswered posts | View active topics It is currently May 7th, 2026, 10:37 am
Reply to topic  [ 236 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24  Next
 Olive the Blueberries & Cream D*lly
Post Re: Olive the Blueberries & Cream D*lly
Here it is the nut splitter:
http://www.ebay.co.uk/itm/2-PCE-BROKEN-CORRODED-DAMAGED-NUT-REMOVER-SPLITTER-SET-/130836552066?pt=UK_Hand_Tools_Equipment&hash=item1e76775982
Anyone tried one?
Ben
March 12th, 2013, 2:29 pm
Have used one similar to that on my Mini back in the 90's. Worked fine (before crap imports from China). Do you have enough room to fit it? I took apart a LMA engine that had done 250,000kms and the nuts looked like yours but with correct socket and slowly, slowly they came off... Just go by feel, if it feels wrong stop...
March 12th, 2013, 2:41 pm
The nuts on the clamps were at least as bad but came off ok. You might be right about lack of space especially the ones at the rear.
Ben
March 12th, 2013, 3:09 pm
worth buying a decent quality nut splitter IMO
March 12th, 2013, 3:23 pm
James, is the one in that link decent enough? I quite like the price on that one :D
Ben
March 12th, 2013, 3:48 pm
I'm sure it'll do the job,
But id still buy a decent quality one that will be good time after time.. ;)
March 12th, 2013, 3:52 pm
I've had a pair of spliters for years they are excellent and have never failed to do the job, access might be a bit tight on a 2cv. If you've safe room an application of heat wont go amiss if you can't use spilters. As Ken posted brass nuts are the way to go,at one time brass was the norm on manifolds on all the cars I've worked on over the years. Which ever way you go gently does it is the method :-)
March 12th, 2013, 5:48 pm
All eight nuts/bolts were liberated on Thursday 8-)
Went gently-firmly with lots of duck oil, spray grease and shock and unlock spray.
One of the studs unwound itself with the nut attached, being the only odd thing to happen.
Hopefully tomorrow I can get the replacement manifold in place.
Ben
March 16th, 2013, 3:31 pm
Lady Luck was on your side today...
Is the sun shining as well? :)
March 16th, 2013, 5:30 pm
Glad it went OK for you. :) :)
March 16th, 2013, 6:23 pm
Users browsing this forum: No registered users and 284 guests
