View unanswered posts | View active topics It is currently May 7th, 2026, 11:56 pm
Reply to topic  [ 438 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 44  Next
 1988 2cv D*lly bits and bobs
Post Re: 1988 2cv D*lly bits and bobs
it did change after i wiped it with a rag, it didnt go, but it may well be paint, thats just turned brown from yellow with the oil etc
odd how ive never noticed it before,
i re set tappets every oil change anyway, but i havent ever bothered to do the heads
September 11th, 2011, 8:52 pm
That is definatly yellow paint.
September 12th, 2011, 1:07 am
It always surprises me just how different cars are. James' car is a totally different drive to mine. It drives nicely though, steering's tight, clutch feels nice, etc.. It is a bit hesitant in second, but makes up for it in third. Compression is pretty damn fine.
The only possible issue with James' car is it eating points and condenser, I can't understand why it burns them out so quickly.
September 12th, 2011, 1:38 am
James, don't forget that if you put a heavy flywheel on you'll need to put a three spring clutch on too, which also involves changing the release bearing on the gearbox.
September 12th, 2011, 1:56 am
Thats why i got a 123 ignition, I ran for years adjusting and replacing points and condensers which needed doing every 500km's or so and given i made a lot of 800km trips interstate it drove me nuts! 123 ignition was the best investment i made on the car! Well apart from the $350 towing fine i got for leaving it parked in a clearway overnight after a late night call from my ex girlfriend, that was also money well spent :lol:
Harley
September 12th, 2011, 7:50 am
voltage reg, earthing of the engine as well as correct coil would be my checks
points need a "run in" tine then they settle and give 1000s of miles of life - the weak point being the condenser. Vellaman/smiffy sparks does away with the condenser
September 12th, 2011, 8:16 am
RT ecas sell a diaphragm clutch to fit the heavy flywheel. Will I still need to change the bearing??
The voltage isn't too high. But it may be half a v too low, and it's on as I believe an original coi,
September 12th, 2011, 8:56 am
You might, I'm not sure. But if it comes with one, you might as well change it while you're there.
September 12th, 2011, 2:14 pm
Ok, thanks RT :D
September 12th, 2011, 2:24 pm
Are you sure?
Check the things the man says!
September 12th, 2011, 9:38 pm
