View unanswered posts | View active topics It is currently February 3rd, 2026, 9:05 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
Wanting to brace the top of the air shock mounts still further i decided to make up a simple bar that would bolt in behind the top of the shocks and also allow the coil and the breather box to mount on...
www.evilbens.blogspot.com
June 9th, 2014, 9:24 pm
I can still use the standard HT leads too...
June 9th, 2014, 9:25 pm
Next step cut down things so they line up again :mrgreen:
First the handbrake gets the chop...
The linking rod also needed cutting down...
June 9th, 2014, 9:28 pm
The gear rod came next... a quick cut and shut...
Next the oil filler/breather... man how complex are these... cut down and turned to clear the fan housing...
June 9th, 2014, 9:32 pm
The oil cooler was moved sideways and the pipe work cut down and swopped to hose..
The base of the oil filler needed heating and dollying to clear..
June 9th, 2014, 9:37 pm
Time to sort the alternator... first the lower pre heat pipe was cut off and removed and a new smaller belt adjuster made up...
Still wanting the correct pre heat pipe to work i decided to lower it down on the exhaust manifold, first step a new hole..
June 9th, 2014, 9:43 pm
The top hole soon got welded up and the pre heat reattached in its new position...
Back on the car with a collar added it was then welded back into place...
June 9th, 2014, 9:47 pm
The fan had some trimming to clear the oil cooler and got bolted back into place...
Just the small belt cover to sort...... the great news is the bonnet now shuts again.. very happy :mrgreen:
June 9th, 2014, 9:52 pm
8-)
June 9th, 2014, 10:19 pm
And when your car is finnished nobody sees the many work involved just to channel your car.....
LIAL. Like it a lot. :D :D :D :D :D :lol: :lol: :lol: :lol:
June 9th, 2014, 11:04 pm
Users browsing this forum: No registered users and 857 guests
