AZL57
 Re: My Beduino
there is a firm in the us that makes copper head gaskets on measure.
| January 11th, 2020, 6:15 pm |
Roger V
 Re: My Beduino
Well, that shows its not to uncommon. I'll try making my own. Always seem To have an issue with the exhaust manifold blowing, so thought it may be more resilient.
| January 11th, 2020, 9:26 pm |
Ianredspecial
 Re: My Beduino
Ecas do a copper one. I used it but it didn't do any good for my endlessly blowing manifold. Timeserts were the way forward for me. Not put in by me, crucially....
| January 12th, 2020, 11:30 pm |
Roger V
 Re: My Beduino
Ian I dont recall ecas doing a copper exhaust gasket! They do a 'carbon fibre' gasket, or copper plated nuts, but cant see a copper gasket.
| January 12th, 2020, 11:48 pm |
Ianredspecial
 Re: My Beduino
Pretty sure I got them from there, by ringing Roy.
| January 13th, 2020, 2:05 am |
Roger V
 Re: My Beduino
Thanks Ian, I'll bear that in mind.
| January 14th, 2020, 11:41 pm |
Roger V
 Re: My Beduino
I've installed the MAP pipe over the last few days. The sensor is on the ECU, and there is a pipe to the manifold.
MAP at idle is hovering around 55 kpa which is quite high.
| January 19th, 2020, 5:55 pm |
lpgo
 Re: My Beduino
Roger V wrote: I've installed the MAP pipe over the last few days. The sensor is on the ECU, and there is a pipe to the manifold.
MAP at idle is hovering around 55 kpa which is quite high. Do you have the right sensor configered in the software??? Is it around 100 when the engine doesn,t run.. (100 is the airpressure)..
| January 20th, 2020, 1:16 pm |
Roger V
 Re: My Beduino
Hi Geo Yes, I'm sure its correctly configured. What MAP do you get at idle? That will give me a target to aim for.  Edit There is a different sensor in the drop down list. I will try it tomorrow.
| January 20th, 2020, 8:31 pm |
Lars E
Joined: April 17th, 2009, 8:30 pm Posts: 111 Location: Aale city, denmark
 Re: My Beduino
My 2cv whit Mega Squirt i about 50 kpa at idle
2cv special 0,6Tii viewtopic.php?f=5&t=1610 http://snail.s4.bizhat.com/viewtopic.ph ... orum=snail
| January 22nd, 2020, 5:27 pm |
Users browsing this forum: No registered users and 172 guests |
