View unanswered posts | View active topics It is currently February 3rd, 2026, 9:42 pm
Reply to topic  [ 144 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
 1976 Dyane 6.52
Post Re: 1976 Dyane 6.52
I will try it - save a bit more money
March 26th, 2012, 10:41 pm
Jameswallace wrote:
Why do you need to run on high quality unleaded?
Only if your sporting 9.0.1
I run my 2cv (8.5,1) on 95 Ron, and it runs fine. No different than that odd occasion on payday I put the high quality stuff in..
I wouldnt even bother putting in an additive either
The octane is one thing, but super unleaded has far less ethanol in it than normal unleaded. If you are driving through France or other EU countries do not be tempted to put E10 Unleaded in your tank, try to use Super/Super unleaded if you can.
At the moment a lot of testing is taking place to see what the effects of this will be on vehicles not designed for it, however I will say that I recommend that if you haven't replaced your original fuel line yet then this is something you should consider doing sooner rather than later. The fuels these days seem to attack the old style rubber.
In the UK we are luckier than most as we haven't got E10 yet and the FBHVC is working with the DfT and oil company reps to ensure that owners of classic cars (and yes 2CV's and A series are regarded as such) will be able to continue using their vehicles.
FBHVC latest on ethanol in Fuel -> http://fbhvc.co.uk/2012/02/24/fuel-stakeholder-meeting-17-february-2012/
1973 Ami 8 Club
March 27th, 2012, 10:50 am
95 ron available all around here and never come across Bio fuel E-10 (Maybe I have been lucky). Had a long trip to Germany last year and filled up many times but always standard fuel selection in each station. Thanks for warning as wifes car uses standard 95 Ron
March 27th, 2012, 3:58 pm
I've never come across e10
March 27th, 2012, 8:41 pm
Very happy today as car was featured - in smallish way in Planete 2CV and they had nice things to say about it. :D
March 30th, 2012, 7:10 pm
Nice one. Always good to see your car in print. :)
March 30th, 2012, 7:13 pm
Run in the new engine and took it for a spin down to Vannes (400 kms) on route national. Sat there for most of the way at 5000 rpm (100kph) and returned 70km per gallon (around 44 miles per gallon). Not bad - I would like to see modern cars run at 5000 rpm for so long - it must be like driving one in 3rd gear - I wonder what mpg they would get. The oil temp (different thread) in the rocker covers only got above 50 deg C when I stop for petrol when it rose to 75 deg C until I started car and then the cooler oil took it back down.
April 25th, 2012, 7:57 am
Busy gathering bits for turbo project. Items bought
IHI RHB31 TURBO
SU 1 1/2 inch carb
38mm dia pipe and bends for turbo manifold to engine
38mm Daewoo throttle body - for future (fuel injection)
High temp gasket material
Oil feed Aeroquip hose and connections
Pieces on order - local machine shop making exhaust flanges and carb mount
Exaust bends etc - from Austrailia
Turbo will be mounted above starter motor - position to be set by slicone hoses etc
Will get all bits before I take Dyane off the road as it is used almost daily
May 25th, 2012, 5:05 am
Sounds like a great setup! Wishing you all the best 8-)
The 1 1/4 SU carby would be even better suited to the 2cv, more progressive, smoother control of the throttle. Even the Daewoo throttle body that I also use for my fuel injection is a bee's dick to big, but definitely the smallest, cheap alternative I could find in any scrap yard!
Please tell which company in Australia you are using as I may do the same :D
CHeers,
Harley
May 25th, 2012, 4:04 pm
Exhaust bits
http://www.ebay.co.uk/itm/110760926479? ... 1497.l2649
May 25th, 2012, 7:13 pm
Users browsing this forum: No registered users and 472 guests
