View unanswered posts | View active topics It is currently May 7th, 2026, 4:44 pm
Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
 1966 RHD belgian built AZL, UK supplied
Post Re: 1966 RHD belgian built AZL, UK supplied
Joe Ahvee wrote:
i would happily drive it in that condition, albeit more roadworthy (chassis and welding)
Can we just stop here, instead of spoiling the whole thing with...
and with a 602 unit.
May 26th, 2010, 8:40 am
That is kind of the trouble with this car. It is beyond careful preservation, which I'd like to have done with it. It needs a complete rebuild. At that point do you find it a period, but better chassis, buy the repro early chassis that is available from Cassis et al, or say sod it and fit an SLC chassis and a Dyane engine and create something that isn't period correct but will cruise happily. Frankly I don't know, at the moment I have a foot in both camps.
May 26th, 2010, 11:16 am
There are already umpty-several RHD/602/disc "oldies" kicking about.
What's _different_ about this? It's originally factory RHD, at a time when there were (effectively) none. For that, it has historical interest. Saying "Well, if I can't preserve, I might as well just modify" denies the value in any kind of historically-sympathetic restoration.
All those Slough 2cvs, John Sobey's RHD aks400 & RHD Ami 6. Bijous. The restored TPV prototypes. Might just as well disk & 602 the lot...
May 26th, 2010, 11:21 am
True enough, but that is a fundamental question about restoration. The simple fact is that the chassis isn't going to be repaired, it is far too rotten. At that point you can either replace it with something that is identical, so no one will ever know that it has been replaced. It won't be "original" though because it didn't leave the factory with that actual part.
Or the other school of thought is that you replace it with something of at least equal quality, but strikingly different so the history of the object can be read by those looking at it in the future.
The truth is that I can see merit in both approaches, and I've done both before, though I actually normally tend towards the rather more purist end of restoration.
May 26th, 2010, 11:42 am
Easily identifiable as replacement, yes - but not markedly changing the design and function.
May 26th, 2010, 11:43 am
That gets my vote. 8-)
I agree with those sentiments too. But what's the solution other than to sell it to someone that will painstakingly restore it? It rather comes down to how much money/time/patience is available to be expended on the restoration. In a way owning something rare is like owning a listed building I suppose, there are considerations over and above the obvious ones of simply putting it on the road. Maybe a nice compromise could be found?
May 26th, 2010, 11:49 am
Hi,
Peter invite me (by email) to jump into this topic. So I jump ;-)
In 1966, the following models were still made in Forest:
AZA (AZ) : chassis number like 11X xxxx
AZM3 : chassis number like 12x xxxx
AZS (AZL) : chassis number like 13x xxxx
AZAM6 (cent. cl.) : chassis number like 300 xxxx
AZAM6 (norm. cl.) : chassis number like 31x xxxx
AZU : chassis number like 12X xxx
AK350 : chassis number like 20x xxx
AKL : chassis number like 25x xxx
The car was probably made in 1966 and directly used in UK.
Vincent
A 1953 - AZL 1955 - AZU 1956 - AZUL 1959 PB - AZS 1960 - AZL3 1960 - AZL3 1961 - AZS 1961 - AZU 1963 - AK350 1965 - AZAM6 1967 - 2CV4 1972
Les Filles de Forest
May 26th, 2010, 12:15 pm
Does there need to be a different solution?
When it comes down to it, if you want a 2cv that drives like a modern one but looks '60s, it'd be a LOT quicker/easier/cheaper to cosmetically four-light/old-taillight-panel a RHD '70s/80s car than restore this.
May 26th, 2010, 12:18 pm
... my 2 cents: not knowing any other 2CV like this one (Made in Belgium in '66 for the UK market), it could be good to restore it close to the original.
If you don't want, I could maybe ;-)
Vincent
May 26th, 2010, 12:32 pm
Only insofar as the owner might not wish to do that. Owning something rare is such a double edged sword isn't it?
May 26th, 2010, 12:38 pm
Users browsing this forum: No registered users and 154 guests
