View unanswered posts | View active topics It is currently February 4th, 2026, 1:50 am
Reply to topic  [ 337 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 34  Next
 My new 2CV, running restoration. In theory..
Post Re: My new 2CV, running restoration. In theory..
Just bought the panels to finish the lower body. I need a lie down o_O
December 3rd, 2011, 2:54 pm
Well I've taken 4 days off work, and am attempting to get the floors done.
First I made a sheet metal folder, to save a bit of money making simple panels.
Before
After. The metal cost me £4.00, a bit cheaper than the alternative in Machine Mart and works ok, so jobs a goodun.
First bit to tackle was the rear floor section. Was slightly rusty.
Heelboard end was rusted so cut that out and replaced.
Almost non existent D pillar bottom
New section made and welded in
I bought one seat box end piece, so I could copy it and make the other side.
Mine is the one on the left.
Fitted
Closing panel made and fitted
Other side wasn't as bad, but got the same treatment.
Centre section was holed, so cut that out and replaced.
Flipping it over tomorrow and might get the bulkhead done.
December 20th, 2011, 11:04 pm
Just realised I shouldn't have boxed in the seat box end, as I now won't be able to weld the inside of the sill end.. >_< will instead cut a hole in the sill, weld it from the inside, then weld the outside of the sill back up.. happy days. Sean did warn me of this, but I forgot.
December 21st, 2011, 1:49 pm
TBH wouldnt worry about it too much, as long as the weld is good on the external stuff and when you fix the seat box corners you make sure the metal extends down to the lower edge of the sill so its welded in with the flange of those home made panels it'll be fine.
i like to make the panels the same but go for lap joints rather than the messy flange ;) - keep it all as clean as possible and there is less for the crap to stick to and start the rot.
December 21st, 2011, 2:03 pm
Like that tool... :)
www.2cvkeza.com
December 21st, 2011, 2:43 pm
Ah right, we'll see, it'd be easy enough to cut a bit out of the sill and weld it up again, got some .8mm cutting discs, makes jobs like that quite easy.
You're right, I should have done lap joints.. oh the joy of hindsight. Oh well, I have a feeling this won't be the first 2CV I'll do, so lesson learnt.
December 21st, 2011, 5:04 pm
Bulkhead next.. Due to RHD bulkheads not being available, I got LHD one and with a bit of jiggery pokery changed it to RHD.
One LHD bulkhead
Sections cut out and swapped round
Welded
Time to get rid of this mess..
Trial fitted, with self tappers.
Chassis dug out of storage, and body put on top to align bulkhead and floor panels.
A pillars were gone at the bottom, so went about repairing those with some scrap pillars.
N/S
O/S also
Off with the old sills
Quick alignment check with the doors on
And all zipped up
This is what I did to get around the cock-up earlier, fitting the seat box ends before welding the sills in..
and on with the floor pans
That's all for this now. Didn't get round to doing the A panels, will wait til next year, along with upper bulkhead and the front end.
Happy Yule folks! :)
December 24th, 2011, 4:54 pm
Sterling work in Stirling!
December 24th, 2011, 6:05 pm
Love the Tartan Rug spark blanket.... :lol:
December 24th, 2011, 8:26 pm
Haha.. thanks. It was just to protect the chassis from scratches. Remarkably, no festive pyrotechnics ensued.
December 24th, 2011, 8:56 pm
Users browsing this forum: No registered users and 629 guests
