View unanswered posts | View active topics It is currently February 3rd, 2026, 3:31 pm
This topic is locked, you cannot edit posts or make further replies.  [ 183 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19  Next
 1968 Ami Club Break
Post Re: 1968 Ami Club Break
Cool, are you having any Citroen service decals on the car?
March 17th, 2012, 10:14 pm
Not for the moment.
Shouldn't know where to put the service decals on the car. Doors could be an option, but don't think that would look good.
As for the handeling with the toyo's, no problems so far.. Drives really well!
Must say they are balanced, which makes driving WHOT a smooth experience!
March 19th, 2012, 10:55 am
Small update..
Car has now a working (whats in a name) handbrake..
after the gearbox rebuild last year I didn't connect the handbrake due to missing bolts on the end of the cables.
car needs a new MOT next month, so it comes in handy if the handbrake works.
Furthermore I put some grease in the kingpins and knife edges.
also a new dashbord is mounted. now i can see how much fuel is in the tank in stead of averaging the movement of the fuelgage.. also the speedometer is more accurate :P
April 23rd, 2012, 10:15 am
Ami is at a handyman at the moment to get the rear wheel bearing replaced..
MOT-APK tester thought they were too noisy. I knew the left one was..
also the track rod end gaiters, end pipe of the exhaust and the front lights had to be changed.. Will go back next friday orso the get is tested..
This is the first MOT since I have it, and when it passes i have an 2 years APK
May 7th, 2012, 8:55 pm
succes
May 8th, 2012, 4:47 pm
Is every APK for two years, or is it because of it's age?
May 9th, 2012, 9:40 pm
Two years because of the age. When a car is 30 years old, you'll only need to go every two years.
If the car is before 1960, you dont need an APK at all....
May 9th, 2012, 10:33 pm
Ami is MOT'ed recently, so i can (ab)use it again for the next two years.
Today I've put some clear lenses on the front indicators:
June 23rd, 2012, 5:13 pm
Looking good! :)
June 23rd, 2012, 5:16 pm
Well, not much to report on this car..
Still runs, although it had some issues starting last friday.
Once it started id had no power and struggled to get past 30km/h.
Left it at work, and Saturday went back to repair it. Other coil, leads and plugs.
Started immediately and runs like before, 120km/h without issues.
Nothing else to report about on this car!
December 17th, 2012, 12:31 pm
Users browsing this forum: No registered users and 314 guests
