Author |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2227 Location: South-Limburg
 Re: Yellow Dyane
Why you want them off?
June 7th, 2021, 4:18 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 877 Location: Rhayader Mid Wales
 Re: Yellow Dyane
To fit to the new chassis. AZL57 wrote: Why you want them off? P1030369 by Robndaisy, on Flickr I couldn't get the flamer to turn cold and didn't want to heat the flamer up in case I disturbed the high tensile metallurgy stuff, so ground away enough of the threaded bush and then some hammering of it to expand the flamer and it gave up  . I'm too mean to buy a 26mm. spanner just for this job.
June 7th, 2021, 7:45 pm |
rob massey55
 Re: Yellow Dyane
I got real and warmed the threaded bush with a Gaz blowlamp until the thread sealant melted, out they came dead easy.
June 8th, 2021, 6:24 pm |
AZL57
 Re: Yellow Dyane
They stil look in good shape seen the rust around.
June 8th, 2021, 9:31 pm |
rob massey55
 Re: Yellow Dyane
June 9th, 2021, 1:46 pm |
rob massey55
 Re: Yellow Dyane
P1030386 by Robndaisy, on Flickr Took last week as a holiday, here we go at this back door bodyshell repair. P1030377 by Robndaisy, on Flickr Where the lower C post? joins the sill, this outer corner brace has a friend on the inside too. That makes a four piece laminated rust explosion; anyway, I will re-use this. P1030380 by Robndaisy, on Flickr profile with one layer removed. P1030384 by Robndaisy, on Flickr Had to modify the end of the repro sill as usual. P1030395 by Robndaisy, on Flickr I'll sort that out when the bodyshell has been inverted. P1030392 by Robndaisy, on Flickr The door and it's gaps look OK, the top hinge mount on the B pillar has stress cracked, so I'll braze that up later...probably much later P1030397 by Robndaisy, on Flickr Not pretty but strong enough. P1030394 by Robndaisy, on Flickr A different curved profile on the repro, P1030393 by Robndaisy, on Flickr Different width too  ,note the gap between the edge of the floor pan and the sill, there was a lot of factory mastic in there, in fact that's all that was left  . The one on the other side of the car doesn't look as bad, but we all know what it'll be like  .
July 26th, 2021, 11:41 pm |
AZL57
 Re: Yellow Dyane
Well happy welding...
July 27th, 2021, 5:01 pm |
rob massey55
 Re: Yellow Dyane
P1030401 by Robndaisy, on Flickr Why the B post rusted through behind the top right passenger door hinge I don't know, but I need to fix it so I can check the gaps before welding in the new C post... P1030399 by Robndaisy, on Flickr once that was attended to, I could cut and fit the C post. P1030402 by Robndaisy, on Flickr Fitted the tailgate before welding, just to make sure nothing started to move. P1030405 by Robndaisy, on Flickr P1030404 by Robndaisy, on Flickr If I was restoring the car, I'd fit new inner wings and a new boot floor, but this is a re-build so I'm patching in new pieces, gonna need more Cleco clamps! P1030403 by Robndaisy, on Flickr Citroen used a lot more body mastic on the Dyane compared to the 2 2cv, and it's helped the rust to really get going  , this is just from around the area I'm working on  . My auto darkening welding helmet has gone on strike so no more welding for a bit, thank Flame  .
August 21st, 2021, 7:14 pm |
rob massey55
 Re: Yellow Dyane
P1030410 by Robndaisy, on Flickr Damn! Screwfix got this in for me too quickly, no more excuses... P1030408 by Robndaisy, on Flickr the little ball of wire is not your friend when plug welding into 6 mm. holes, so snip it off each time. Note: that is the boot drain hole in the picture, which I am not going to block up  . P1030411 by Robndaisy, on Flickr Just a few more patches and the quilt will be ready to turn over  .
August 31st, 2021, 8:45 am |
rob massey55
 Re: Yellow Dyane
P1030412 by Robndaisy, on Flickr Wow! that was some earthquake  .
September 3rd, 2021, 8:36 pm |
Users browsing this forum: No registered users and 20 guests |
