View unanswered posts | View active topics It is currently August 14th, 2025, 12:10 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
It's going to sit low... :mrgreen:
www.evilbens.blogspot.com
December 1st, 2013, 11:32 am
wow ! ace!
December 1st, 2013, 12:16 pm
evilben wrote:
These have taken some tracking down but will look great....
Very happy with these.... :mrgreen:
Where did you get these bad boys from and were they pricey???
Dyane 12 1976 (ish)
December 4th, 2013, 11:51 pm
And f##k that's low....loving it.... :D
Dyane 12 1976 (ish)
December 4th, 2013, 11:53 pm
Italy and they cost £ 60.00, ok not cheap but if you want these things....
December 5th, 2013, 8:53 am
I want the kc spotlight covers! reminds me of my old tamiya RC sand scorcher!, when I was about 12!
December 5th, 2013, 1:47 pm
Time for an update... onto the rear suspension mods, first off i worked out where the rear shocks needed to be on the rear arms and made up and welded on the brackets needed. the rear inner wings got cut out so the shocks have the space needed...
lower plates were made up out of 4mm steel and drilled and bolted into place top and bottom of the chassis legs...
January 4th, 2014, 6:29 pm
The underside upside down :D these plates will get welded to the new chassis on the final refit...
January 4th, 2014, 6:31 pm
Onto these the rear frame needed to mount the top of the shocks off started to get welded into place, i decided to mount the air tank, compressor and battery all onto the same frame..
January 4th, 2014, 6:36 pm
The compressor hangs off the back as close to the battery as possible as it will need a direct feed..
January 4th, 2014, 6:38 pm
