Author |
J-dub
 Re: Yet another red spesh...
good work lad! i like the seat could you not get it just a few more mm lower speedbumps? or is that a swear word these days? keep up the good work russ
July 8th, 2010, 10:26 pm |
Joolz
Nice  , how much clearance have you got around the rear wheels with the wings on? That front hub tool's far to clever looking to simply hold the hub while undoing the nuts, does it hold the hub at the same height as it is with the wheel on it? Could be useful for turning the arms you'd be able to tack them together on the car, less chance of cocking up the angle. That seat looks familiar, have you worked out how to get in it yet, without climbing through from the passenger side?
July 8th, 2010, 11:38 pm |
Russell
Joolz wrote: Nice  , how much clearance have you got around the rear wheels with the wings on? I've no idea, as the shell is currently sitting about half an inch too high at the back because the bumpstops are in contact with the arm. It's not a great deal of clearance, but I think it'll be ok. Joolz wrote: That front hub tool's far to clever looking to simply hold the hub while undoing the nuts, does it hold the hub at the same height as it is with the wheel on it? Could be useful for turning the arms you'd be able to tack them together on the car, less chance of cocking up the angle. I reckon you're right. Joolz wrote: That seat looks familiar, have you worked out how to get in it yet, without climbing through from the passenger side?  I'll either trim it down a bit, or just get in the passenger side.
July 8th, 2010, 11:51 pm |
Joe
Ridiculously talented and you done even know it by the sounds of it. excellent work Russ.
July 8th, 2010, 11:58 pm |
Neil
Joe Ahvee wrote: Ridiculously talented and you done even know it by the sounds of it. Yeh, he does.
July 9th, 2010, 7:31 am |
Russell wrote: I've no idea, as the shell is currently sitting about half an inch too high at the back because the bumpstops are in contact with the arm. Not been restored "OOP North" then looks verry verrrry cool( sick, bangin or wateva da youth say nowadays) Sean
July 9th, 2010, 7:40 am |
Little Louis
you could go through the roof to get into that seat.
July 9th, 2010, 7:55 am |
Russell
Little Louis wrote: you could go through the roof to get into that seat. I have been thinking about that. If I got an externally opening roof I could do away with the need to use the doors. The drivers door will be nigh on useless with that seat and the roll cage chicken bars I hope to fit. I think it's probably going to be a case of trial and error when the cars in use, to see which method of entry is easiest. The last few bits are at work, and yesterday we started drawing out and making the roll cage on my bench. I won't lie, I've never been involved in structural design and have only got the intention of making a cage that looks the part, in fact, as and when the car goes on its roof the cage will most likely do more harm than good, but all the time it's wheels are on terra firma, it should look the tits.
July 10th, 2010, 12:20 pm |
Tom Duckpower
Joined: August 18th, 2009, 10:31 pm Posts: 1244 Location: Berkel-Enschot, Netherlands
Russell wrote: I have been thinking about that. If I got an externally opening roof I could do away with the need to use the doors. How do you want to close the roof once you're in the car? You could make a hybrid roof. Externally closing roof to get in to the car, and an Club-roof-bracket-thing to close the roof when you're in the car.
 1986 Citroen 2CV6 Special Pick-Up 1964 Solex Oto Van der Heem
July 10th, 2010, 12:31 pm |
Russell
Tom Duckpower wrote: Russell wrote: I have been thinking about that. If I got an externally opening roof I could do away with the need to use the doors. How do you want to close the roof once you're in the car? You could make a hybrid roof. Externally closing roof to get in to the car, and an Club-roof-bracket-thing to close the roof when you're in the car. Yep, that's a very good point! It'd probably just be easiest to use the passenger door I guess.
July 10th, 2010, 12:36 pm |
Users browsing this forum: No registered users and 31 guests |
