View unanswered posts | View active topics It is currently July 4th, 2025, 6:53 pm
Reply to topic  [ 455 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 46  Next
 Yet another red spesh...
Post Re: Yet another red spesh...
It's OK, Russell's having a hunt for the micrometer... :lol:
Joolz wrote:
:twisted: Looks promising, have you jumped up and down on it, much travel in the springs?
June 29th, 2010, 1:45 am
That's looking good, run over a fag end and you'lll be able to tell if it's plain or filter tipped :lol:
June 29th, 2010, 2:02 am
is this still going to be a pop crosser?
pop cross as in offroad circut and lots of contact :?
June 29th, 2010, 7:45 am
No, I just used the chassis from it for the time being.
Tonight was full on FAIL. Fitted the turned arms and they are nowhere near turned enough for it. Will have to remove them again and redo them. Also it's only got a degree or two of negative camber and I was aiming for at least 5 which is what the Ami has. Back to the drawing board!
June 29th, 2010, 9:53 pm
we all have epic fail days
oh well
good luck!
June 29th, 2010, 10:14 pm
Right, sod all has happened to this car for a bit, so this evening I decided to give myself a major enthusiasm boost and see if it's as low as I wanted.
First, I had to change the arms, I didn't have a G rim so I made this bit of kit at work to help undo the hubnut....
Then, me and Dad put the body back on...
Luxury seating...
I am so happy. just a few odd bits of welding to do and then it's time to slap it back together and upset the MOT tester.
July 8th, 2010, 9:23 pm
Nice work! Car looks really good with the white rims and wider tyres!
And nice tool you made! Think they will sell well if you make a few (I like to have one ;) )
July 8th, 2010, 9:28 pm
I will try and make some more then!
Most people use a GS wheel which has a hole in the centre, or cut an old 2cv wheel so it can be used in the same way. I prefer to do this though.
July 8th, 2010, 9:36 pm
8-) 8-) 8-) 8-) 8-) 8-)
You do know how to make a cool looking deuche .... 8-)
July 8th, 2010, 9:37 pm
Good work fella!
July 8th, 2010, 10:02 pm
