View unanswered posts | View active topics It is currently May 7th, 2026, 7:47 pm
Reply to topic  [ 182 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
 Early Ami
Post Re: Early Ami
there may be a small circular disk poped to the bulkhead in the engine bay it will be stamped with 3 numerals or AC### that's the factory code, plenty on line lists of the colours
Mat may have a better idea where it might be or what any alternate markings may be for that age of Ami
October 14th, 2012, 1:59 pm
Post Re: Early Ami
Right I should have remembered that. the Little Disc says AC 117 so a quick check Says Bleu Brouillard.
Fantastic stuff Cheers
So that'll be Fog Blue then
October 14th, 2012, 4:12 pm
Post Re: Early Ami
Did a bit of patch making today
Not happy with the front 90 degree curve where it goes towards the sill so that will need tightening up
Quite chuffed with the swage I put in using a Hammer and the gap between 2 paving slabs as a D*lly
Its nearly time for hot metal glue. a few more fillets to make and its going to start being stitched up.
October 28th, 2012, 7:38 pm
Post Re: Early Ami
Wow!! I am very impressed by your determination mate....I had one of these Amis up til January when I then sold it to Russ....they are fantastic cars but rust like a bean tin on the beach....like Russ said, the A posts are the hardest bits. And good rear wings ar ethe hardest panels to find, though GRP ones are slightly less rare.
I no longer run Citroens but will be keeping an eye on this thread and will chip in with anything that I learnt about in the 3 or 4 years I had mine.
Very best of luck with it all
October 30th, 2012, 7:05 pm
Post Re: Early Ami
Thanks Willami It looks like I have a big day coming tommorrow I have not taken pictures but the A Posts are indeed toast.
Everything all went a bit dusty when I got the sander out and the paint off.
The Door and wing is off. and i have drilled the spot welds off the top hinge mount, this bit is mostly OK bar a little bit at the bottom thats holed.
There is nothing under the bottom hinge mount.
there was about 2 spot welds holding on to the top mount the rest was lace.
There really is not anything there to patch up :lol:
There is a section of about 4 inches in the middle that is good metal.
The inner where it meets the parcel shelf is holed as is the bulkhead around that area.
Looks like I will be heading off for some more steel stock tomorrow. :lol:
October 31st, 2012, 12:00 am
Post Re: Early Ami
I've just bought one of these ^^^^ unseen and it is being delivered first thing in the morning...
.......... there may be trouble ahead... :shock:
.... good going for a VW specialist :D
www.evilbens.blogspot.com
October 31st, 2012, 10:14 pm
Post Re: Early Ami
@Mr Unhinged ... Nice project you have here... :)
If you dont have front pedal panel take a look of this pictures... It is my work and if you need contact me...
Uploaded with ImageShack.us
www.2cvkeza.com
November 1st, 2012, 10:59 am
Post Re: Early Ami
And some pictures of my previous project AMI6... for help to see how it is assembled piece by piece... :)
www.2cvkeza.com
November 1st, 2012, 11:02 am
Post Re: Early Ami
:lol:
They are really interesting and cool cars Ben, However i have NEVER seen anything rust quite like them.
Good luck and please get a thread going on it.
November 1st, 2012, 1:40 pm
Post Re: Early Ami
Keza that is beautiful work, and I may well be in contact with you next payday.
Have you thought about doing A Panels?
If you did there would be Ami people around the world seeing you as a Hero
Thanks for showing some detail pictures as it is really going to help me.
:D
November 1st, 2012, 1:50 pm
Users browsing this forum: Google [Bot] and 214 guests
