View unanswered posts | View active topics It is currently February 4th, 2026, 3:05 am
Reply to topic  [ 372 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 38  Next
 Yellow Dyane
Post Re: Yellow Dyane
Skilled hero in my book.
May 30th, 2020, 5:46 pm
ImageP1030009 by Robndaisy, on Flickr
This is what can happen when 'someone who should know better' uses an out of balance knot twist rotary wire brush without the guard. No cut (lucky for me) and the brush is in the bin. It ripped off the interior sound deadening/ sealer a treat mind :).
ImageP1030013 by Robndaisy, on Flickr
Cutting through, leaving the original piece as something to weld to.
ImageP1030015 by Robndaisy, on Flickr
Now that's out of the way it's easy to trim the outer remnants from the inside.
ImageP1030016 by Robndaisy, on Flickr
Bolted onto the chassis and this is what you want to see, the toeboard panel sitting evenly across. seriously good panels Ken ;) .
ImageP1030020 by Robndaisy, on Flickr
the outer panel, held off by the original pressings, will either flatten then or cut around them for final fixing.
ImageP1030021 by Robndaisy, on Flickr
This repair panel fits well tidy. The front outrigger underneath will have to be replaced.
ImageP1030022 by Robndaisy, on Flickr
The driver's side (nearside, right hand ) is along way from shore though :D.
May 31st, 2020, 7:36 pm
ImageP1030036 by Robndaisy, on Flickr
Finally was able to break out the welder and fasten the outer front sill repair that i'd made, permanently :) .
Tomorrow, the inner and maybe the front floor panel, maybe :D .
I'm so slow these days it's pathetic. :roll:
June 12th, 2020, 8:48 pm
ImageP1030039 by Robndaisy, on Flickr
modified an axle stand to support the corner of the body while cutting around the the floor outrigger. Hung the door to check gaps ok.
ImageP1030042 by Robndaisy, on Flickr
ImageP1030044 by Robndaisy, on Flickr
ImageP1030045 by Robndaisy, on Flickr
ImageP1030047 by Robndaisy, on Flickr
As far as I got, driver's side almost ready for welding in, and passenger side (which needs a lot of work) started. :)
ImageP1030046 by Robndaisy, on Flickr
The trouble with Daisy being stuck in Portugal is that I have to make my own lunch these days :lol: .
June 13th, 2020, 7:21 pm
Doorsteps look delicious :D
June 13th, 2020, 7:47 pm
Coming along nicely :) Better than my painting. :D
You got any mustard? :)
June 13th, 2020, 11:12 pm
ImageP1030053 by Robndaisy, on Flickr
That's the inner piece of the triangular toeboard being welded in thank flame!
welding to decent steel like this is a pleasure, welding to the Citroen 'bean can' steel is usually fizzy but sometimes ok. This is when a Bedouin appeals, 'cos any offcuts could go into the woodstove :D
June 28th, 2020, 7:16 pm
The way I feel about the Shed sometimes, the whole Bedouin could go in the woodstove. :o
June 28th, 2020, 9:04 pm
ImageP1030064 by Robndaisy, on Flickr
The floors going in, driver's side done, just doing passenger's. Back on the windscreen surround tomorrow, :) .
When bodyshell is flipped, I'll be able to finish closing off the ends of the sills etc. glad that's done, eventually :roll: . Like me, you're probably sick of looking at it :lol:
July 3rd, 2020, 6:20 pm
This dyane in your hands makes me think of this song :
https://youtu.be/IQNBQI3UDag
July 3rd, 2020, 7:13 pm
Users browsing this forum: No registered users and 871 guests
