My new 2CV, running restoration. In theory..
Author |
panelbeaterpeter
Joined: April 24th, 2011, 6:05 pm Posts: 226 Location: Everywhere
 Re: My new 2CV, running restoration. In theory..
While I'm saving moneys for new floors, sills and bulkhead, I thought I'd get on with some "free" things. Decided to commit suicide. Scrounged a pair of B pillars and rear door hinges..  And proceeded to unpick the door hinge first of all   Welded it to the edge of the front door  Dressed  Unpicked the hinge section of the pillar  Cut it down the length to remove the section  Positioned and tack welded to the front of the existing B pillar, clamping it to the rear hinge, using a nut as a spacer to obtain a uniform gap  Then seam welded down the length  Welds dressed, catch bracket removed, and all etch primed.  Fitted the door and it wouldn't shut fully so I cut a sliver off the edge of the door and welded it up. On looking at the rear doors, they are like this too. I won't be fitting the rubber to the rear of the front doors, same as the front of the rears.  It works and EVERYTHING!!   Blanked the old handle hole, keeping the hole to relocate to the front. Will figure out the latch and handle at some point..   Also shortened the lamp bar by 45mm each side.   Considering deleting the rear quarter window.. likely would use metal though, and not masking tape.  More at some point in the vague future.
_________________ (°\=/°)
Last edited by panelbeaterpeter on September 25th, 2011, 8:20 pm, edited 2 times in total.
September 25th, 2011, 8:18 pm |
J-dub
wow ive always wanted a suicide door 2cv
September 25th, 2011, 9:33 pm |
J-dub
ps how are you filling in the rear quarterlights? it looks amazing, are you going to top it off with a old fashion hood? (no boot lid)
September 25th, 2011, 9:34 pm |
panelbeaterpeter
Jameswallace wrote: wow ive always wanted a suicide door 2cv  Your not having it!! I'm going to fill in the rear windows with trifle sponges. Nah I'm keeping the boot lid, I like the practicality and the fact I won't need to shell out a load of cash on a new 'ood. Not sure what I'm doing with the rear lights yet though, so rear end design is not certain. One things for sure, the horrible trailer board rear lights are for the bin.
September 25th, 2011, 9:44 pm |
Matt_S
Joined: July 28th, 2010, 11:50 pm Posts: 590 Location: Northumberland
Fantastic job indeed, going to look spot on once finished, and glad to see ya putting some mods on like the suicide doors..carry on the good work mate...
Would love you to attack my dyane aswell mate, but fancy it would cost a small fortune!!
Dyane 12 1976 (ish)
September 25th, 2011, 9:46 pm |
J-dub
panelbeaterpeter wrote: Jameswallace wrote: wow ive always wanted a suicide door 2cv  Your not having it!! I'm going to fill in the rear windows with trifle sponges. Nah I'm keeping the boot lid, I like the practicality and the fact I won't need to shell out a load of cash on a new 'ood. Not sure what I'm doing with the rear lights yet though, so rear end design is not certain. One things for sure, the horrible trailer board rear lights are for the bin. fancy doing my doors?
September 25th, 2011, 9:49 pm |
panelbeaterpeter
Thanks people, James, get the the bits and pay me the money and yeah sure I'll do it  took me half a day to do that side, but a lot of that was figuring it all out, the other side should be easy. Saying that I've not got round to the catch and handle bit yet, I'd like to order up all the right bits from Club Cassis, but that costs a small fortune.
September 26th, 2011, 9:17 pm |
pbpeter, seems that someone from 'a land down under' is working on the same alteration to his 2CV. < http://snail.s4.bizhat.com/viewtopic.ph ... orum=snail > Not quite sure what Harley means by a bear claw catch, but if it's something which is going to hold the front doors closed better than the original 'cupboard door' catches, I reckon it's a darn good idea. If they do let go, they make quite a mess, especially if it's on a van. I've driven a 1950s 2CV about 30 miles each year for MOT and was so worried about the doors blowing open that I used to have a couple of luggage straps hooked between them... ken.
September 26th, 2011, 9:32 pm |
ken wrote: pbpeter, seems that someone from 'a land down under' is working on the same alteration to his 2CV. < http://snail.s4.bizhat.com/viewtopic.ph ... orum=snail > Not quite sure what Harley means by a bear claw catch, but if it's something which is going to hold the front doors closed better than the original 'cupboard door' catches, I reckon it's a darn good idea. If they do let go, they make quite a mess, especially if it's on a van. I've driven a 1950s 2CV about 30 miles each year for MOT and was so worried about the doors blowing open that I used to have a couple of luggage straps hooked between them... ken. Ken "bear claw " is the modern car latch where the pawl (sp) rotates around the fixed part its supposed to be anti burst as there is also the keyway element that means it cant be pulled apart
September 26th, 2011, 9:43 pm |
Little Louis
ken wrote: I've driven a 1950s 2CV about 30 miles each year for MOT and was so worried about the doors blowing open that I used to have a couple of luggage straps hooked between them...
Olli's old van used a caribiner clip to hold the doors shut.
September 26th, 2011, 10:14 pm |
Users browsing this forum: No registered users and 18 guests |
