View unanswered posts | View active topics It is currently May 7th, 2026, 9:42 am
 1968 M4 Dyane
Post Re: 1968 M4 Dyane
It's no spring but an oiling tube you see here. There are rings that clamp in the grapite-ring.
If you take the middel screw of the fork you can slide the forks axle out. Than you have enough place to change the ring.
May 25th, 2019, 10:24 pm
I tried sliding the axle but it hits the back of the brake drum. Do I need to take that off or is there a way of twisting it somehow?
May 25th, 2019, 10:54 pm
If the axle is slit to one side don't you have enough play in the fork to unhook the ring?
Take care not to loose distance rings of the fork to center it on the axle.
May 27th, 2019, 8:01 am
It honestly does lever out with a screw driver.
May 28th, 2019, 11:50 pm
Users browsing this forum: No registered users and 282 guests
