View unanswered posts | View active topics It is currently February 4th, 2026, 1:49 am
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 my 83 2cv6 'CLUB'
Post Re: my 83 2cv6 'CLUB'
Just realised, didn't mention that those peg bolts are standard M8 thread, so Citroen must have had an off day by not using their preferred choice of b'stard thread. :lol:
db78 wrote:
Thanks Ken, I will have a read of those links at lunch time and then give the engine some loving at the weekend.
August 28th, 2013, 10:12 am
How does this part work? Doesn't appear to move..
Have lubed it so hopefully it frees off. I am guessing its headlight adjuster, should it pull or twist from inside the car.
August 28th, 2013, 10:50 am
haha! as a new found expert on this particular element of the car, I can answer that!! :D
on the right hand side (in your case) under the top dash you should see a big knob! , it turns to raise and lower the headlights when weight is in the rear, its a simple system of a thread in a brass barrel, wd40 on the thread I guess if its stuck...ohhh feeling pleased with myself I can answer a tech question!!
August 28th, 2013, 11:20 am
Brass?
You must have the rare deluxe version.
Next thing you'll be telling us yours has got stainless steel floors... :lol:
August 28th, 2013, 11:28 am
haha! all the dirt gives it a brassy sheen! ken you should at least be pleased I can answer the "starter for 10 " question ! :lol: ...by the way I´m following this with regards spacing and shims and all that lot as I´ll have to do the same :D
August 28th, 2013, 12:12 pm
db78 ---looks like the "r" pin and a washer is missing from the tip of the rod
if it is, the light bar won,t move when u wind your knob :)
August 28th, 2013, 1:05 pm
You have answered my next question... Should there be an R clip.. will get this working on my next visit then.
Anyone got a front rubber floor liner kicking about? Mine is non existent. :-(
August 28th, 2013, 1:24 pm
i tend to leave then up as the floor rots away with all the water trapped beneath
August 28th, 2013, 3:08 pm
Yep. I have a right hand drive rubber mat with cut out for organ pedal accelerator. It's got a couple of splits, but is basically sound. £10 secures plus postage. Whereabouts are you?
John Jordan
August 28th, 2013, 4:22 pm
Could you send me a picture?
August 28th, 2013, 5:11 pm
Users browsing this forum: No registered users and 616 guests
