View unanswered posts | View active topics It is currently August 13th, 2025, 6:50 pm
 Tunes
Trouble Maker
Post Tunes
Well I'd like some help.....
I'm thinking I'd quite like to be able to hear some music in the old "Meg" 4x4 but have to take in to consideration that the car gets very wet inside.
As an old git, I know absolutely nothing about subs (yellow marine), woofers and tweeters (dogs and birds). Let not even talk about head - units.
I thought about mounting a player (ipod/cd) up high in the roof and I really liked the transmitter thing you young uns had at the national.
Any advice welcome on what to buy and how to mount a record/cd/ipod/mp3 player in me car.
Rich
www.barbour4x4.com
October 13th, 2009, 12:21 am
Post Re: Tunes
If your not bothered about getting any head-
unit. Then i would recommend trying the same kind of setup as mine. if you just pick up a cheap 2 channel power amp (mine was £40) you are able to plug a 3.5mm to aux lead into it , which will allow you to play anything with a headphone out socket. (have plugged laptop in when ipod ran out). Then you can hook up a couple of 6x9's in a position of your choosing.
As for where to mount the amp. I have got mine under the rear seat, which of course may be a problem if your car leaks in that area.
October 13th, 2009, 12:35 am
Trouble Maker
Post Re: Tunes
Thanks Steve
Seems a good idea - the car is a 2cv 4x4 (orange one on the front page). It goes into deep water up to and over the seats - as per last years Villevenard, so I think needs roof mounting.
I saw something I think was Russ's car which had speakers in the roof. Are 6x9s speakers? Is that the size?
Rich
www.barbour4x4.com
October 13th, 2009, 12:43 am
Post Re: Tunes
Rich, take a look at oboes car in dover, could mount the headunit in the same place. Im sure he will be along in a bit to post some pics...
October 13th, 2009, 12:47 am
Trouble Maker
Post Re: Tunes
Thanks Max
I really know absolutely nothing about car hifi - so needs to be in plain speak.
Cannot mount anything on front shelf either as fills with water there.
Thanks
Rich
www.barbour4x4.com
October 13th, 2009, 12:51 am
Post Re: Tunes
Ill explain it slowly for you if you want? Before you consume beer.
October 13th, 2009, 1:00 am
Post Re: Tunes
Little Rich wrote:
Thanks Steve
Rich
Yeah i guess roof mounted would be the best option, in that case a head unit will be smaller and probably easier to mount up there. Probably the more exensive option, and maybe a little more fiddly to get the flashing lighty thing to make noise come out. whereas with a power amp you press play on your device and plug the wire in.
As for speakers size is up to you really, you can choose to sacrifice volume and quality in favor off something that will fit exactly where you want it.
October 13th, 2009, 1:13 am
Post Re: Tunes
My speakers are on plates welded in to the roof, they could be rivetted in though which would mean no costly painting work, you could spray the plates with a can. The speakers are in pods which are 16cm size, you can buy the pods for various size speakers on ebay for about a tenner. You could also think about marine speakers and head unit, they are more waterproof.
October 13th, 2009, 8:07 am
Post Re: Tunes
You want to get that bald bearded bloke to take you along to the boat show and have a look at the stereo stuff intended for marine use - BEFORE you hit the Guinness stand.
Have you considered that given how civilised 4x4s tend not to be, you're going to need some considerable welly to drown the car itself out?
October 13th, 2009, 9:00 am
Post Re: Tunes
You can get waterproof head units and waterproof speakers from places like Force4 Chandlery http://www.force4.co.uk/c/81/Marine-CD-MP3-Radios---Speakers.html
Waterproof, £139, comes with speakers, amp + wiring http://www.force4.co.uk/5129/Force-4-Waterproof-MP3---iPod-Kit.html
I was thinking of doing this for the Mehari :)
...and just in case, a watertight case for your iPod
http://www.force4.co.uk/5156/Force-4-iPod-Video-Waterproof-Case.html
I'd go with sccoba's suggestion of an amp with speakers attached.
October 13th, 2009, 11:23 am
