View unanswered posts | View active topics It is currently May 26th, 2026, 8:33 pm
 Transporting a 2cv body
Post Transporting a 2cv body
Hi All,
What sort of van has been used to transport a 2cv body (safely) with van doors shut.
VW T5???
Regards
Peter
August 14th, 2019, 1:40 pm
Post Re: Transporting a 2cv body
citroen jumper? I did transport them on an little camper trailer several times.
August 14th, 2019, 4:17 pm
Think sprinter and vw crafter definitely
Brian...
August 16th, 2019, 10:22 pm
Thanks Guys,
My VW Transport's load bay is about 130mm too short.
But maybe I can leave the door's open a bit?
August 17th, 2019, 9:35 am
You could load the body-shell with the front higher .
If you have some wood or anything else, you could make a sort of a bench in the front of the bay , so the front of the shell is higher and stabil .
It just could make the difference .
August 17th, 2019, 10:22 am
@Geert,
Had similar idea, the "diagonal" line is longer.
With the shape of the front part of the body, I think its a case of seeing if its fits
August 17th, 2019, 11:09 am
with the body upside down it's easier to tilt it.
August 17th, 2019, 1:53 pm
Wont fit a T4/5
Sprinter/Crafter and you're golden, you can drive a 2cv straight into one.
August 19th, 2019, 9:16 pm
And nope, for sure will not fit a VW Transporter. We tried. Right way up, on its side, upside down, with the B pillars closed up with a ratchet strap...
August 19th, 2019, 9:24 pm
Users browsing this forum: HMW and 40 guests
