View unanswered posts | View active topics It is currently July 20th, 2025, 12:52 pm
Reply to topic  [ 7 posts ]
 Quality of repo tie rods
Post Quality of repo tie rods
I would like to be able to lower my car more :twisted:
Can anyone comment on the quality of these parts from Ecas?
http://www.ecas2cvparts.co.uk/suspension-longer-30mm-than-standard-p-1618.html
On the other hand I would like to know that they are threaded all the way in so that I can still raise the car to the max to go raiding!
Cheers,
Harley
October 13th, 2014, 1:39 am
Post Re: Quality of repo tie rods
Can't comment on thread depth, but ECAS only sell quality parts with a first class after sales service if problems do occur.
John Jordan
October 13th, 2014, 8:59 am
If ECAS buys them from Burton, which look the same as that on on the picture... I can say they look good (can look in the material and weld obviously) I just fitted a set of Burton eyes last weekend.
Mine were not threaded all the way but just 15 to 20mm simular to original Citroen ones. The rest was just hollow, however not sure if they are hollow over their entire length. I would ask Roy to be sure.
October 27th, 2014, 11:40 pm
Harley,
isn't the required length of thread engagement in a bolted connection usually quoted as "at least 1 x nominal diameter of the thread"?
After that, any extra threads will be contributing very little to the strength of the connection, which is why Citroen only threaded that portion of the original tie rod ends which had a reduced external diameter.
I'd be more worried about that part of the thread on the tie rods which has been exposed to the atmosphere for a couple of decades; the threads on original tie rods were rolled rather than cut, but any loss of metal due to corrosion could be a problem if you need to wind them right into those longer tie rod ends...
October 28th, 2014, 1:03 am
Mine don't show signs of wear after 6000km
October 28th, 2014, 8:39 pm
Ive had those fitted on my Dyane for 28000 miles no problem.....
www.evilbens.blogspot.com
October 31st, 2014, 9:56 am
Thanks for the replies everyone.
Harley,
Good point ken, I assumed thy would be a full thread internally as opposed to a length of thread and cavity (not knowing how they are manufactured).
I guess if they where fully threaded it would aid with the point you raised about the corroded thread on the tie rods. I had not considered the effect of the corroded threads, better check them out.
Harley
November 3rd, 2014, 7:44 am
