View unanswered posts | View active topics It is currently August 11th, 2025, 5:58 pm
Reply to topic  [ 4 posts ]
 C15
Post C15
I've just fitted a new alternator to C15 1.9 diesel engine. I need to tension the belt. Does anybody know how the belt tensioner is loosened?
It appears to have a 26mm(?) spanner sized nut with one of those odd allen key
type bolts (can't temeber thier name) in the centre of it (I have neither of the tools to investigate)
Thanks in advance.
June 28th, 2013, 7:46 pm
Post Re: C15
If you don't get a reply on here, it might be worth asking on:
http://visaforum.freeforums.org/
or:
http://www.frenchcarforum.co.uk/forum/viewforum.php?f=3
June 28th, 2013, 8:15 pm
Post Re: C15
Thanks Neil I'll try that.
June 29th, 2013, 8:04 am
Post Re: C15
Easy when you've got the tools! 50 Torx key to release, 27mm ring spanner to adjust/hold tensioner to desired position retighten Torx bolt.
July 1st, 2013, 9:51 am
