Drawings/dimensions for 2cv towbar?
http://international2cvfriends.com/forum/viewtopic.php?f=4&t=4822
Page 1 of 1
Author:  Hannahman58 [ June 4th, 2013, 9:49 pm ]
Post subject:  Drawings/dimensions for 2cv towbar?
Anyone got a drawing or dimensions for a tow bar to suit a galvanised chassis on my 2cv?
I plan to make one in work, just thought it wold be easier than guessinwhere it lots to!
Cheers
Paul
Author:  Russell [ June 5th, 2013, 12:00 am ]
Post subject:  Re: Drawings/dimensions for 2cv towbar?
Which chassis do you have? I recently made one for my car, but I also happened upon one that I removed from the car some years ago. There's not much measuring required, a couple of crossbars to each chassis leg and a single central spine for the towbar.
Author:  Hannahman58 [ June 5th, 2013, 9:07 am ]
Don't really know what type?
It's lake a ladder type galvanised
Any dimensions would do, I can check if it will line up easily enough
Cheers
Paul
Author:  J-dub [ June 5th, 2013, 9:11 am ]
Id bolts bits on to get an idea for support, and tac weld as you go, then remove for proper welds
Only cos i cant measure for shit!
Author:  Terry [ June 5th, 2013, 11:15 am ]
Pics speak louder than words ....
"Witter" towbar,fitted to an [early] non-galvanised SLC Chassis.
Dimensions .....[in inches ....sorry,I dont do "Euros"]
Looks like this when bolted to the car.
:shock: OMG ......I had'nt realised that the underside of my car was so rusty & crusty .... :oops:
And yeah .....I know I'm a cr@p artist,and an even worse photographer,so if anyone can do better,please feel free to have a go y'self .... :P
hth
best rgards
T.
Author:  Hannahman58 [ June 5th, 2013, 3:10 pm ]
Thanks mate!!
having worked from sketches on the back of ciggy packets for 30 odd years, yours is a Rembrant!
Thats all the info i will need.
thanks again, just got to find some shiney stainless steel in work now to knock one up!!
Author:  ChrisW [ June 5th, 2013, 5:45 pm ]
Just to add to the discussion - I saw a tow bar the other day that had the front legs going all the way to the large bolts that hold the rear beam on. I thought this looked a stronger than drilling the thin chassis.
Found it....
http://www.2cvp.com/detail/attelage+com ... 26-150.htm
Author:  Terry [ June 5th, 2013, 8:17 pm ]
Found it....
Yeah .....that would be better if the car still had the original chassis,the rear legs often rot through [being "closed" box section prob'ly dont help].....however,SLC chassis's are stronger than the original ones anyway and the rear legs on mine aint an enclosed box section.
btw .....that SLC chassis was fitted to my 1988 [Portugese built] 2cv in 1995 .....my original chassis was fubar'd after only 7 years.
best regards
T.
Author:  Russell [ June 5th, 2013, 8:57 pm ]
I welded in a new crossmember to mount the central hitch piece and as a jacking point, then I welded a plate to the central piece which bolts to the rearmost chassis crossmember. I wanted something that could be removed quickly as I generally don't like having a towbar on the car.
Author:  Hannahman58 [ June 12th, 2013, 5:53 pm ]
Made the towbar from some nice stainless found in work, but will leave the final weld of the tow ball end until I get a rear bumper so I can judge where it sits
Thanks for all who assisted
Cheers
Paul
