View unanswered posts | View active topics It is currently August 11th, 2025, 5:42 pm
Reply to topic  [ 10 posts ]
 Drawings/dimensions for 2cv towbar?
Post Drawings/dimensions for 2cv towbar?
Anyone got a drawing or dimensions for a tow bar to suit a galvanised chassis on my 2cv?
I plan to make one in work, just thought it wold be easier than guessinwhere it lots to!
Paul
June 4th, 2013, 9:49 pm
Post Re: Drawings/dimensions for 2cv towbar?
Which chassis do you have? I recently made one for my car, but I also happened upon one that I removed from the car some years ago. There's not much measuring required, a couple of crossbars to each chassis leg and a single central spine for the towbar.
June 5th, 2013, 12:00 am
Don't really know what type?
It's lake a ladder type galvanised
Any dimensions would do, I can check if it will line up easily enough
Paul
June 5th, 2013, 9:07 am
Id bolts bits on to get an idea for support, and tac weld as you go, then remove for proper welds
Only cos i cant measure for shit!
June 5th, 2013, 9:11 am
Pics speak louder than words ....
"Witter" towbar,fitted to an [early] non-galvanised SLC Chassis.
Dimensions .....[in inches ....sorry,I dont do "Euros"]
Looks like this when bolted to the car.
:shock: OMG ......I had'nt realised that the underside of my car was so rusty & crusty .... :oops:
And yeah .....I know I'm a cr@p artist,and an even worse photographer,so if anyone can do better,please feel free to have a go y'self .... :P
hth
best rgards
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
June 5th, 2013, 11:15 am
Thanks mate!!
having worked from sketches on the back of ciggy packets for 30 odd years, yours is a Rembrant!
Thats all the info i will need.
thanks again, just got to find some shiney stainless steel in work now to knock one up!!
June 5th, 2013, 3:10 pm
Just to add to the discussion - I saw a tow bar the other day that had the front legs going all the way to the large bolts that hold the rear beam on. I thought this looked a stronger than drilling the thin chassis.
Found it....
http://www.2cvp.com/detail/attelage+com ... 26-150.htm
June 5th, 2013, 5:45 pm
Found it....
Yeah .....that would be better if the car still had the original chassis,the rear legs often rot through [being "closed" box section prob'ly dont help].....however,SLC chassis's are stronger than the original ones anyway and the rear legs on mine aint an enclosed box section.
btw .....that SLC chassis was fitted to my 1988 [Portugese built] 2cv in 1995 .....my original chassis was fubar'd after only 7 years.
best regards
T.
2CV6 Special [Red]
June 5th, 2013, 8:17 pm
I welded in a new crossmember to mount the central hitch piece and as a jacking point, then I welded a plate to the central piece which bolts to the rearmost chassis crossmember. I wanted something that could be removed quickly as I generally don't like having a towbar on the car.
June 5th, 2013, 8:57 pm
Made the towbar from some nice stainless found in work, but will leave the final weld of the tow ball end until I get a rear bumper so I can judge where it sits
Thanks for all who assisted
Paul
June 12th, 2013, 5:53 pm
