View unanswered posts | View active topics It is currently June 25th, 2025, 5:00 pm
Reply to topic  [ 10 posts ]
 noticed today?
Post noticed today?
My battery trays loose,and both sides bulkhead around tray have
a 2inch long split :roll: is this a common 2cv fault or just mine :?:
January 4th, 2012, 7:54 pm
Post Re: noticed today?
Very common on late UK cars.
January 4th, 2012, 7:55 pm
You need this.......
http://www.ecas2cvparts.co.uk/battery-s ... p-522.html
January 4th, 2012, 7:57 pm
Really common, I'm guessing your 2cv is a disc brake car? The older models used to have an extra double thickness plate to prevent this but it was deleted around the time of disc brakes to save money or something, every late 2cv suffers from this, and ecas, I believe, sell a battery tray strengthening device to stop it going further.
Yep, up until the early 80s? Citroen fitted a bracket under the battery tray to help support the weight. Cost cutting meant on later cars all the weight bares on the flimsy bulkhead - cracks were common after 12 months back then!
ECAS sell this:
January 4th, 2012, 8:01 pm
Thanks for all replies,ive already been cutting steel this after noon
to repair and make a strengthener bracket,coudnt believe how flimsy
the bulkhead is there, :shock:
January 4th, 2012, 8:10 pm
Cracks in the bulkhead will fail the MOT and will need to be welded before adding the bulkhead support bracket. (if they can be seen under the bracket obviously ;) )
January 5th, 2012, 11:05 am
Welded my split bulkhead and added an ECAS frame a couple of years ago. No probs since.
January 5th, 2012, 7:19 pm
Mine has a very bad crack here too, will be welding it up and making a strengthening piece which I will spot weld behind, will look neater than the Ecas plate. The thickness of the bulkhead metal is just ridiculous.
January 5th, 2012, 9:26 pm
0,5mm
January 7th, 2012, 6:20 pm
