View unanswered posts | View active topics It is currently July 18th, 2025, 11:52 am
 Engine cooling tin
Post Engine cooling tin
I am curious....the black part's between the top and cylinders. Why is it there, and which engines had it?
Piture borrowed from this site
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
October 26th, 2011, 11:33 pm
Post Re: Engine cooling tin
German market. To reduce spillage if leak from head occurs. Anti-pollution I think.
John Jordan
October 27th, 2011, 12:17 am
Much more likely to be 'anti-carbon monoxide in hot air delivered to passenger compartment if joints between cylinder heads and barrels leaking', unfortunately... :|
Only seen these ducts on German market engines.
October 27th, 2011, 12:42 am
Ok.... Only on German car's. That's why I have never seen them. But seriously.....how can those things do ANYTHING with a leaking head/barrel? Strange things.
October 27th, 2011, 1:18 am
Hi EirikJ,
they cannot limit or prevent the leakage of combustion gasses from the joint, however they probably do quite a good job of directing them away from airflow which could reach the cabin.
The outlet from that cowling is on the underside of the head and if erosion of a cylinder head joint does happen, it's invariably most severe diametrically opposite the spark plug...
p.s. Wonder why some of the photographs on that site have been flipped horizontally? :?
October 27th, 2011, 1:35 am
Ah, ok, an outlet on the underside. Well, I guess there is some thinking behind them and a function. Still a bit strange though hehe....
October 27th, 2011, 1:41 am
Not only German engines - I got a replacement engine for Steves Dudley when I wanted to rebuild its original engine due to eroded cylinder head and had it out of a C plate english registered original engine D*lly....
October 27th, 2011, 9:56 pm
Nels,
I think you'd have to look at an awful lot of UK registered cars to find another one like that.
The first engine I found with that fitting was from a German car which had only been in the UK 24 hours before it was torched in the student area of Leeds.
The second one was on Daz's German registered 2CV4 engine, never seen another one in 30 years of working on these cars...
October 27th, 2011, 10:02 pm
Must admit when I got it home and went to put it in the car I thought "what the feck are they" very strange and I couldnt see a real point to them - also a right pain to get off when they are old as I swapped one of the heads for the eroded head once I put new pistons in the old block and had a right faff getting it off....
October 27th, 2011, 10:08 pm
Surprised you didn't make the connection... :roll:
Also hope you sorted out the ignition timing so it didn't happen again.
October 27th, 2011, 11:04 pm
