Dash and Bulkhead insulation.
http://international2cvfriends.com/forum/viewtopic.php?f=4&t=2677
Page 1 of 1
Author:  dave 411 [ February 6th, 2011, 6:59 pm ]
Post subject:  Dash and Bulkhead insulation.
Not sure where to post this,so I will try here.
I need to buy some dash and bulkhead padding/insulation/whatever it is called.I have ripped all of mine out as it had gone hard and was coming off anyway.There dose'nt seem to be a lot of choice available so I was wondering if anyone has bought some and what the quality was like.
I have seen all the usual places selling it,Ecas,Franzose,Frome 2cv,but without actually seeing it,its hard to judge the quality.
Any help or advice would be appreciated.
Author:  Lenny [ February 6th, 2011, 11:31 pm ]
Post subject:  Re: Dash and Bulkhead insulation.
I've just used some of this on my current pain in the arse:
http://www.woolies-trim.co.uk/p-1206-heavy-hardura.aspx
Not the easiest stuff to work with but it looks good now it's in place.
Author:  Smiffy [ February 6th, 2011, 11:56 pm ]
I spent a while trying to replace my collapsed dash/bulkhead insulation with stuff like the original Citroen padding. The 2cv people in Halifax said that I could have some, but I'd have to cut it to shape myself, and go up to their place to fetch it.
Eventually I gave it up as a bad idea (why buy stuff that tends to sag and collapse?) so I bought some stuff called brown bread, which is pretty thin and does a good job of deadening the noise. It's easy to cut with scissors, it's simple to work with... and has an adhesive backing. I was able to cover the main part of the bulkhead with just a couple of pieces, and made a patchwork of the fiddly bits.
It looks fine (has a reflective finish, giving a kind of space-age ambience! ;) ) but when I get round to it I'll cover it with leatherette trim (the same as the stuff I've used on my door cards).
Hope this helps.
