Author |
Luke
 Re: this years MOT questions
Fair enough. Last MOT I had, was for my bike. Pretty much the first thing the chap said was "A bulb horn's not acceptable for a bike that age." and pretty much the last thing he said, as he handed me the green sheet, was, "We'll pretend you fixed the horn." So I guess I'm not in much of a position to say anything!
First thing I think I'd try is probably another bulb, particularly if you've had any from Halfords?
November 3rd, 2010, 9:43 pm |
J-dub
i got them from uncle R, im going to swap them over to see if it does it whilst it is in the other unit,
November 3rd, 2010, 9:50 pm |
Joe
i had the headlight problem too, check the earth is clean and all the connections are good on the lightbar.
November 3rd, 2010, 10:08 pm |
J-dub
ok thanks  its the headlamp end obviously, not my dim dip relay wiring  !!
November 3rd, 2010, 10:10 pm |
J-dub
Well Mot time again
No reasons to fail, infect the not tester should get one up over the condition of car after the chassis change!
November 6th, 2011, 12:11 am |
J-dub
3 adviserys. Front wheel bearing (which is fine) and both front kingpins (told the mot tester he needs to learn to test a car, an they where fine particularly as one kingpin is brand new) but I still walked away with 3 adviserys but a pass overall
November 7th, 2011, 9:56 pm |
J-dub
Wasn't wheel bearing it was oil leak the third. But that's 'cos when I oil changed a week or two ago, I spilt loads down the engine when topping up!!!
November 7th, 2011, 10:02 pm |
J-dub
Lenny wrote: http://www.dealerplates.co.uk/
I've used this chap in the past. Can't fault him. Correct pre-2001 font and dealer info etc. 25 quid a pair. Went to order closed  ((
September 14th, 2012, 2:53 pm |
ayjay
twofifty AZU wrote: Jameswallace wrote: ive read the regs,. but cant desiphar something. on my new plate, the holes go through the letters, now am i write in thinking that it should have black studs, as the studs are whitte, now is this a fail or adviser?? im going to colour them in with permenant marker if the local plate man cant come up with the goods You're over intellectualising this. It is just an MOT. Unless the screws are deliberately placed to alter the meaning of the number plate no one is going to be in the least bit interested. If your car has No structural rust No big chips in the windscreen directly in the driver’s line of sight Legal tyres Functioning brakes and no rusty (to excess) brake pipes Decent exhaust Working lights Working horn Working wipers and washers Freshly greased non fubarred kingpins Half decent wheel bearings No sharp edges Working seat belts without cuts Then it’ll pass; the MOT is a minimum standard. It really isn't that hard to pass. you forgot the rubber gaitors on the steering rod ends
September 14th, 2012, 5:15 pm |
main beam indicator? working steering lock? fog light that isn't in the boot?
dont forget to tell them the parking brake is on the front axle and that yes the suspension tie rods do rattle about when its up on jacks and no there shouldnt be rubber boots or nylon rose type joints either.
September 14th, 2012, 6:11 pm |
