View unanswered posts | View active topics It is currently July 25th, 2025, 5:03 am
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 401, 402, 403, 404, 405, 406, 407 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
But... doesn't 'weight' decrease with altitude given that there's less air mass above it? :?
I do not mean to be rude, but either You're trolling and I've fallen for it, or it's air pressure You mean, which does not really act here, weight (not mass!) is "defined" by Earth's gravity (which is not quite constant, but very close to it) ;)
December 5th, 2012, 7:21 pm
I guess the boffins at The OU would take 'other factors' into account when dealing with this sort of thing. :)
December 5th, 2012, 7:47 pm
Hardly, given that the calculation involved takes only a couple of minutes.
Although they did fall at the last hurdle, since 375,000 Lego bricks would make a stack 3.6 km in height, not 3.5 km.
This assumes that each Lego brick is the standard height of 9.6mm, which excludes those which Russell has remodelled with a lump hammer... ;)
dave 411 wrote:
What a waste of time and money :twisted:
December 5th, 2012, 8:32 pm
Wouldn't those bricks at the bottom have compressed slightly, causing a reduction in the overall height?
December 5th, 2012, 8:53 pm
I believe that weight does decrease with altitude, although mass will of course remain constant. Not as a result of anything to do with the air, but because weight is dependant on the gravitational pull of the earth, the further you get from the earth the less that pull will be.
December 5th, 2012, 9:29 pm
http://www.flickr.com/photos/technicnick/6396837429/
Proper thing to with Lego....
December 5th, 2012, 9:30 pm
Will ya stop being awkward? :lol:
December 5th, 2012, 9:32 pm
Joolz,
even at the top of Mt. Everest (8.848 km up) the reduction in gravitational pull is only 0.28%...
You have to go up as high as the International Space station (400 km) before gravitational pull is reduced to 90% of that on the Earth's surface.
December 5th, 2012, 9:42 pm
james2cv wrote:
Little Louis wrote:
Jameswallace wrote:
It sickens me that i pay more income tax in a monute than starbucks pay coorperation tax in a year!
I applaud them.
Now you're just being deliberately obtuse. :lol:
Tell me you wouldn't do the same in their position?
December 5th, 2012, 10:05 pm
Joolz,
Ok then, based on those figures, and assuming the base of the tower is at sea level, then I calculate the reduction in gravitational pull at the top of a 3.6km tower to be 0.114%. As the gravitational pull will vary slightly for every block, for the sake of the calculation, lets say the overall reduction for the whole tower is 0.114 ÷ 2 = 0.057%.
Therefore the tower which we thought would weigh 432kg, will only weigh 431.754kg, a deficit of 246 grams, and equivalent to 213.6 bricks, which would add over 2 meters to the top of the tower.
Whether that would be cancelled out by the ones at the bottom being compressed I'm not sure, who knows youngs modulus for a lego brick? :P
December 5th, 2012, 10:13 pm
