View unanswered posts | View active topics It is currently July 27th, 2025, 12:49 pm
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 386, 387, 388, 389, 390, 391, 392 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
Like the Trabbi , Its another car on my to do list, but then again so is a Moskvich, Tatra 602, .. the list is endless actually.
Just no more Fiats, one was enough.
November 2nd, 2012, 7:16 pm
does it look like this russ?
if so this might help..
November 2nd, 2012, 7:34 pm
Thanks, I think I've sussed it although with no brakes I can't really get it up to any speed. I've had a good look at it this week and I think I'm going to sell all of my worldly possessions to do a half decent job of it.
Here's an interesting question, is there such a thing on the market as a 12v fuel cut off? Something like a soledoid operated tap? I've had a brief google search but can't seem to find anything that does the job. I want to replace the fuel tap on it with one that closes the fuel off when the ignitions off.
November 2nd, 2012, 8:03 pm
http://proto-pic.co.uk/12v-solenoid-valve-3-4/ something like this? wrong size like... but I'll keep looking.
November 2nd, 2012, 8:06 pm
http://www.autoelectricsupplies.co.uk/p ... tegory/121
tad expensive but that sounds right?
November 2nd, 2012, 8:08 pm
The expensive ones kinda look like what I want, I think. Cheers.
November 2nd, 2012, 8:34 pm
Similar as to what i use russ in my duel fuel 106, except its 3 way, ony thing to bear in mind is they get quite hot when energised
November 2nd, 2012, 11:53 pm
Most modern motorbikes use a vacuum operated tap, they have a pipe to the inlet manifold so that the tap is opened when the engine is running and also a 'prime' position for when the carb has been drained. Any use?
November 3rd, 2012, 12:22 am
Ps yes there expensive. I paid £70 for 2 3 way solonoid valves. Worth the pennys thoygh
Russ what about a conventional fuel valve (stop cock type thing??)
November 3rd, 2012, 12:29 am
I guess that would work, although it doesn't really have an inlet manifold, the carb bolts to the crankcase. I'll have a look and see if there's a possibility of tapping into it, as that sounds like a nice solution.
JW, it has a fuel tap which I keep forgetting to turn off, hence my interest in an automatic means of doing so.
November 3rd, 2012, 12:37 am
