View unanswered posts | View active topics It is currently July 19th, 2025, 12:59 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 255, 256, 257, 258, 259, 260, 261 ... 400  Next
Chris2cv wrote:
Just pull one LT lead off the coil,
Nice idea, but anyone with Entry Level Mechanics could work that one out, don't you think Russ? Surely total removal of the HT leads would be a foolproof method if immobilisation.
If somebody wants a car they'll take it. If they're just out for shits and giggles and it won't start, I doubt they're going to start diagnosing and fault finding.
October 21st, 2014, 10:37 pm
Or swap the lt lead with the oil pressure switch lead, then when your helpful joyrider cum AA patrolman come visiting nothing's disconnected under the bonnet. I just think taking your plug leads with you when you leave the car makes you look like a weirdo and I don't want 3 foot of greasy cabling in my handbag.
October 21st, 2014, 10:41 pm
Would this work?
October 21st, 2014, 10:53 pm
Smiffy wrote:
I'm quite sure it could work but i wouldn't use it in a 2CV, with all the potential leaking ;) every drop on the g-spot could switch your ignition.
October 22nd, 2014, 2:10 pm
Found – most – of a rectangular front indicator for my 1970 2CV.
One to go!
viewtopic.php?f=5&t=5356
October 25th, 2014, 3:03 pm
Free lunch yesterday, in return for parking up at a local market. It is quite a long day though but it was a good lunch. :lol:
October 26th, 2014, 2:25 pm
AZS wrote:
Now tell me what's the diffrence between a normal relais and this??? (ok. women don't have relais inside)...
I think it will work but with a normal relais you achieve exactly the same (but profesional) so why all this????
October 26th, 2014, 8:01 pm
Tripyrenees wrote:
Free lunch...
from your middle picture: is there any significance to the swan on the Citroën badge on the rear of the Traction?
October 26th, 2014, 8:53 pm
Mark....
Rubber engine mounts I believe.
October 26th, 2014, 9:07 pm
Ah Yes! A quick google and that bl**dy swan's everywhere!
Citroën.fr wrote:
Janvier 1931
Création du moteur flottant par Citroën
André Citroën revient des Etats-Unis avec des idées nouvelles dont celle du Moteur Flottant (ou Moteur Floating Power). Une idée qui une fois encore va contribuer à la modernisation de l’Automobile.
Cette innovation consiste à filtrer les vibrations du moteur en interposant, entre celui-ci et le châssis, des blocs élastiques de caoutchouc.
Janvier 1932
Le moteur flottant Citroën
Les C4 G et C6 G (désignées alors MFP pour Moteur Floating Power) sont équipées d'un moteur flottant. Citroën prend une fois de plus de court tous ses concurrents européens. Toutes les Citroën sans exception recevront désormais le Moteur Flottant.
I presumed that it was something to do with 'gliding along' but I mistakenly believed it to be for the suspension, not the engine...
October 26th, 2014, 10:50 pm
