View unanswered posts | View active topics It is currently August 14th, 2025, 1:17 pm
Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
 Time to put a 2cv to sleep for a bit !
Post Re: Time to put a 2cv to sleep for a bit !
2CViking wrote:
Fair enough but I'll ask again. What happen if you don't.
Well,if you leave a vehicle still long enough ,the battery will obviously deteriorate and possibly leak acid causing corrosion. The fuel will go stale and evaporate leaving deposits in the carb which will later cause problems, the pistons when left static in a bore can even seize with corrosion in a damp environment or leave a mark which can turn into a 'high spot' which can be a problem with creating a hot spot certainly in aircooled two strokes in my experience so quite possibly in 2cv as well , the tyres will start to crack at the sides rendering them weaker when they are put back to use plus they can develop 'bulges' where they have been sitting which can be dangerous and could lead to blowouts.
Doing those things are precautions against all those things and ensuring your car is kept in the best state to reinstate it when you return to it ,obviously not all of those things may happen but the longer it is left the more of them will happen and the worse it would be so in my thinking it would better to be safe than sorry .. :|
March 4th, 2010, 11:12 pm
If it was closer I'd offer to start it every now and then
March 4th, 2010, 11:21 pm
Old Bloke
oboe wrote:
its in my Gran's garage and my 80 something gran dont drive :lol: :lol:
would have got 1 of the matlock 2cv'ers to turn it over but there off on there travels to :lol:
and the cars being SORN
cheers for the help ken
Should have brought it down here Chris, I'd have looked after it for you. Remember not to apply the handbrake, take note of everything Ken has written and what ben has pointed out.
I'll send you a PM regarding something else I wrote here before a moderator deleted it.
Have a great trip.
Now known as 602
http://www.2CVTech.co.uk
March 4th, 2010, 11:26 pm
