View unanswered posts | View active topics It is currently August 4th, 2025, 7:39 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 140, 141, 142, 143, 144, 145, 146 ... 400  Next
Nels,
if you ever do another one of those, it makes life a lot easier if that little plate is removed by bending it in the middle.
'Unbend' on refitting... ;)
Nelsthebass wrote:
Replaced front crankshaft oil seal - the original was rock hard and a right twat to get through the hole in the back of the fan cowling and no wonder leaking - then sprayed a few more of the panels in contrasting colours to try and reduce the amount of diarrhoea yellow. Off to The Lamplighters in Cheadle Staffs for a gig in it later tonight - if any one is local they are all welcome!
May 18th, 2013, 9:30 pm
4x4 SuperFinn wrote:
Removed about 4 kilo of mud from the engine bay!!
How did it perform in the terrain?????
May 18th, 2013, 11:06 pm
Had my own snail delivery today......
In dutch it is cold triangelen, I've made this one about 25 years ago and it still does the job,
did about 60 miles with it... today, in all those years I've recorved about 15 cars or more with it doing over 6000 miles I guess...
May 18th, 2013, 11:34 pm
Pictures?
May 19th, 2013, 11:10 am
Drove from Staffordshire to Portsmouth then St Malo to Manot in the Charente. Only problem was at 80k short the wipers jammed.The drivers side being the culprit :-( Without the and blade fitted they worked Ok,so re- positioned the passenger side to wipe a central area and drove on thankful that the rain clear coating I'd used helped the rain blow off the screen.
May 19th, 2013, 7:19 pm
Wipers sorted drivers side very stiff drop arm link caused the support frame to twist and jamb.All bent straight and well lubricated. Note to self must lub more often :-)
May 20th, 2013, 4:26 pm
scared of the dark
Had I seen this before now I would have as the lamplighter is within walking distance!
Some previous cars:
May 20th, 2013, 5:29 pm
7750rpm.
May 20th, 2013, 8:41 pm
My engine shagged yet? ;)
May 20th, 2013, 8:44 pm
Beautifully run in.
May 20th, 2013, 8:46 pm
