Galvanized 2CVs in Denmark
Author |
 Re: Galvanized 2CVs in Denmark
James, I doubt whether hiding the car in a garage will alter the fact that you're living in a marine environment. Some technical stuff to wade through... http://www.galvanizing.org.uk/?cms_id=3 ... 0CorrosionWithin a given local environment corrosion rates can vary markedly. For example, steel may corrode more on a particular side of a building because it is in the shade and so remains wet for longer periods. Prevailing winds may carry airborne contaminants (e.g. exhaust from a power station or sea spray from the coast) predominantly on to one face of a structure. It is therefore the “microclimate” immediately surrounding the structure which determines corrosion rates for practical purposes. Steel is most commonly used in the following environments: • rural atmospheric – essentially inland, unpolluted environments; • industrial atmospheric – inland polluted environments; • marine atmospheric – the 2 kilometre strip around the coast is broadly considered as being a marine environment; • marine/industrial atmospheric – polluted coastal environments; • seawater immersion: (i) the splash zone, immediately above high-tide level, is usually the most corrosive zone; (ii) the tidal zone, between high tide and low tide, often covered with marine growth; and (iii) the low-water zone, a narrow band just below the low-water level; • the permanent immersion zone, from low-water level down to the sea bed;
Jameswallace wrote: Well now you can park your car in the sea. I park my car about 300 metres from the sea Luckily In a garge
October 22nd, 2011, 2:49 pm |
J-dub
Doh
Luckily it's not a wild sea but a harbour
October 22nd, 2011, 3:17 pm |
Erasmo
ken wrote: James, I doubt whether hiding the car in a garage will alter the fact that you're living in a marine environment. Some technical stuff to wade through...
I think that it will help. Sometimes when the wind comes from the sea my car is covered in a layer of salt.
October 22nd, 2011, 8:19 pm |
Users browsing this forum: No registered users and 67 guests |
