View unanswered posts | View active topics It is currently July 20th, 2025, 4:38 am
 Cold Cold Duck
Post Re: Cold Cold Duck
http://www.espar.com/tech_manuals/Older ... 0%20EN.pdf
Pete.
Remember to smile!
February 16th, 2011, 11:11 am
did someone say blanking off the oil cooler was a good way to heat up the car quicker?
February 16th, 2011, 1:18 pm
Yeah, from the backside. Little can of beer or something else and piece from it fits perfectly. Easy to fit and if it gets warmer, easy to slip halfway out.
Pete.
Remember to smile!
February 16th, 2011, 5:24 pm
Wow ! I am still digesting all the info you folks sent my way. Thank you! The vastness of the reservoir of knowledge here is impressive. I will start this weekend with some of the ideas posed and see how it goes. I will keep you posted on the installation of the Espar heater as well.
One thing I have already done is to insulate the walls and behind the door cards with mylar coated bubble wrap. It is thin and very effective. It is a bit bright to use uncovered however. It was much like sitting inside a tin can until I got the fabric covering over it. I have also insulated my roof with a similar material which has fabric already sewn to it.
Here is to warmth!
Adam
February 17th, 2011, 6:33 pm
Good luck!
BTW, I've often wondered about using this stuff for 2CV insulation:
http://buildingmaterials.co.uk/Foil-Ins ... 5-20M.html
It's pricey, but it's meant to be brilliant.
February 17th, 2011, 7:52 pm
