View unanswered posts | View active topics It is currently June 25th, 2025, 3:43 pm
Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
 this years MOT questions
Post Re: this years MOT questions
Well, erm makes life awkward that does russ. Its not a huge hole, but i could stick my pinky finger in thete
September 25th, 2010, 1:15 pm
I think a tester could quite legitimately fail a rust hole in the springcan, it is a stressed part of the suspension.
You could file the hole round so it looked like it was meant to be there, and then put one in the other can too. Or put a piece of gaffertape over the hole and then a coat of under seal to hide it.
If it was me I'd turn it round so it couldn't be seen, but still put some tape over it to stop the water getting in.
It wouldn't be a bad idea to address the cause of the hole, that the canister's got water in, instead of oil.
September 26th, 2010, 1:37 am
yer i spun it round so you cant see it a while back, but its slowly spinning round slowly, so ill have to spin it again. its not a bad idea to tape it and renew then eventuallly, i think its just the one hole, but i will check both sides thoroughly, and in the mean time change them, great, another mind baffeling task ahead of me..
September 26th, 2010, 7:51 am
James, I can see that you're the eternal pessimist!
Jobs really don't have to be and, quite often aren't baffling. If you go into everything that you do with the "this looks really difficult, I can't do that, that looks way too hard for me" kind of aproach, you're more likely to find it hard because you've already convinced yourself.
Coming on here and announcing to the (I2F) world that you're going to find it difficult is only going to reaffirm your beliefs because, as a pessimist, you're more likely to listen to the few bits that people may say are slightly awkward as opposed to the majority which say it's easy!
I probably sound like I'm having a go? I'm not but negativity really pisses me off. If you try something and then find you can't do it, fair enough but, have a go, get your hands dirty and, I dare say, you'll more often than not find that you can do it.
Rant over.
September 26th, 2010, 10:10 am
Im not normally like tht, just seems like a hard task to get all the old stuf into new cans, (im not sure how,) dont you cut open and re weld? I dont hav. Welder..
I will look into it and have ago, im sure i can do it, (optimisim?)
I get wht you mean tho, im not normally like that.
September 26th, 2010, 12:07 pm
I think most people would just put a different can on, not bother with rebuilding it. But seriously, tape over the hole, turn it upside down, put some oil in it, it'll be fine.
September 26th, 2010, 12:21 pm
I thought that the cans came empty wheb u bought it?
September 26th, 2010, 2:26 pm
Joolz is suggesting you fit a secondhand can from a scrap car.
September 26th, 2010, 3:57 pm
True. Good idea, Wish list..!
September 26th, 2010, 4:30 pm
mot booked 3rd november, fingers crossed! got the new number plate to put on the night before the mot!!
any way to stop them splitting? local liscense plate man said maybe a bit of VERY gentle heat may do it...?
October 26th, 2010, 12:03 am
