View unanswered posts | View active topics It is currently August 14th, 2025, 8:54 am
Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 colour of 2cv
Post Re: colour of 2cv
Jameswallace wrote:
im 88 though....
If its the same red as my '88 its Rouge Vallelunga ....
GKB AC 44 on the Citroen tin.
I get my touch up matched at my local refinishing suppliers....the last tin I bought carries the number CR3265 [although obviously thats his mix code].
My "local supplier"? ....Rotherham Refinishing Supplies,Barbot Hall,Rotherham ....tel 01709 328918 .....it aint cheap,but you do get a big tin [400ml,bigger than the 150ml Citroen one anyway]
And if you intend calling "in person" ,your welcome to call in for a cuppa,'cos its only 200yds from my house.
btw .....I'd use a local supplier to get it matched every time .....'cos red fades worse than any other colour...... take the bootlid with you to get it matched.
EDIT ...btw ....if you aint too particular ....Gloss Red Hammerite [Smoothrite] is as near dammit a match .....although the merits of using Hammerite is [imho] doubtful.....it aint as good as its made out to be,and once its on you cant put nuffin else on over it without it reacts.
hth
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
May 26th, 2010, 11:16 pm
thats not a bad idea actually i may do that - as my friend has a proper spray gun and it needs to be in liquid form
i hate spray cans - never been my forte if im honest
well im miles away from that so im afraid i cant take you up on that offer as kind as it is,
i geuss my local halfords could do the paint i geuss, they mix stuff up....
any other suggestions?
May 26th, 2010, 11:21 pm
look in the phone book mate, Halfords are ok if you're desperate, but fairly useless as a pukka paint shop. If that draws a blank, speak to Sam fieldhouse, and ask who painted his car, they were pretty good from what i remember, and they'd probably point you in the direction of a decent pro paint mixing place.
May 26th, 2010, 11:28 pm
just to shed some light as to why i want the paint anyway
when i bought my car (cant stress this enough) it had a dent in it, i didnt do the dent!!
being a young driver everyone assumes it was me!
ive not dented my car...
anyway it was 110£ to have the dent in the wing removed, and looking on ecas i can buy a new wing for 76£ and as the wing is slightly rust i think ill go for the new wing - i also need it as i have a new bootlid (well i say new, its not new one i was given which i sanded all the rust out and primed with red oxide) and need to paint that and i also want to wet flat back my other wings to rid the stone chips in them and also to sand out the rust and make my car look beautiful again
while on the topic of boot lids - any idea how to re fix the citroen 2cv6 special badge and how to get "D*lly" on there - stencil? steady hand?!?!?!
same intentions with the bumpers, i have rust bubbles and as well as the odd rust mark so i put the rust killer on yesterday, most rust has gone, apart from the biggens so ill sand the rust out and spray those up!
russell i will speak to sam, im happy to do the spraying myself with the spray gun as its a proper one, just getting the paint
thanks
May 26th, 2010, 11:29 pm
Well :roll: ....if your intending doing Castle Howard or the Lincoln Bells 'n Whistles Camps,it aint that far outa your way.
btw,I've got compressor & Spray gun .....I find it easier with a big can and one of these ....
...it clips onto the can,like this ...
tip ;) ..... its easier if you use red oxide coloured primer too ... ;)
T.
2CV6 Special [Red]
May 26th, 2010, 11:31 pm
yes my friends spray gun runs of a compresser
130psi i think it kicks the air out of
not sure out the end of the gun though....
yes i thought red oxide was sensible seeing that the bootlid was wight before, just need to wet flat it back and spray nice shiny red
do i need to laqer the paint after spraying? or will it naturally be shiny?
May 26th, 2010, 11:33 pm
Should dry nice and shiny ....if you do it right.
Laquer is only neccessary over metalic ....and even then,it can crack & craze if not applied correctly.
The "D*lly" stickers are available as ....errr :roll: ....stickers.
I cant remember off-hand who sells 'em,but they do most of the "big" meets [Registers Day,International, etc]
2CV6 Special [Red]
May 26th, 2010, 11:38 pm
ok thanks
i will get some help doing it
thanks for your advice and tips
May 26th, 2010, 11:40 pm
D*lly sticker (white)
http://www.ecas2cvparts.co.uk/dolly-sti ... p-460.html
May 27th, 2010, 9:34 am
im sure i miss these things!!
been quoted 100 per panel on my 2cv for a respray, (as in 100 a wing incl paint) does this sound reasonable?
going to get quotes from else where too
thanks
May 27th, 2010, 12:23 pm
