View unanswered posts | View active topics It is currently June 19th, 2026, 4:46 am
Reply to topic  [ 6 posts ]
 Trigger Wheel/ABS Wheel
Post Trigger Wheel/ABS Wheel
Error or What!
Trigger wheel in Alu, can it be used with a VR, Hall Sensor or other? or are they (s)crap :(
September 21st, 2012, 4:05 pm
Post Re: Trigger Wheel/ABS Wheel
Homemade triggerwheel 36-1 (for ignition) with my famous Vr sensor works well for me
http://www.youtube.com/watch?v=7BFBOltFBaQ&feature=plcp
butI think for ABS/tractioncontrol you better can use Hall (zero detecttion) meaning
Hall sensor works from 0 rpm Vr sensor runs from 60 rpm (at least in my ignition 1 tooth)
36 tooth will be less then 60 rpm but never 0....
September 21st, 2012, 10:16 pm
I would make it simpler drilling/milling holes into the disk...
September 21st, 2012, 10:18 pm
Lpgo
The material Aluminium will thats work???
All the commercial items are steel/ferrous.
September 22nd, 2012, 9:30 am
No, it need to be atracked!!!! by a magnet, at least for a vr sensor, some hall sensors do but i think they don.t work well in this case, again drill/mill a pattern in your disks..
September 22nd, 2012, 9:46 am
With it now, :shock:
ps its "Disc"
pps no milling machine
September 22nd, 2012, 1:15 pm
