View unanswered posts | View active topics It is currently June 19th, 2026, 7:15 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 88, 89, 90, 91, 92, 93, 94 ... 105  Next
 Make Your Own ....2CV.... 4x4
Bit more progress..
Plan to block one end of the exhaust and fill with water/washing up liquid, to check for all the holes and weld those up.
Don't think one silencer will be sufficient as the cross box is missing.
March 4th, 2019, 5:24 pm
Out in the Sunlight, can now see just how many bits still need to been fettled.
April 18th, 2019, 2:43 pm
Using the old floors to fill some of the holes in the "colander" body shell also needs a bit o support underneath.
April 19th, 2019, 1:10 pm
Looking awesome :)
April 19th, 2019, 7:56 pm
Plan to remove engine/front gearbox and improve the strength? of the transfer pinion.
Part to be modified, currently only welded.
Drill parallel to shaft and push fit 5mm pins.
May 6th, 2019, 11:48 am
"Try out" to pin gear onto shaft
Using an old gear, have drilled and plugged two 4.9mm holes.
First attempted.
Using 5mm hardened pins od 5mm but they only go in <1mm, had thoughts of getting ground to 4.9mm + but that is a lot of hassle.
Second attempt.
Using 5mm mild steel rod, pin goes all the way through, with small amount of material shaving off as the pin is hammered home.
May 10th, 2019, 3:11 pm
And! ... Does it work?
May 10th, 2019, 10:25 pm
Not yet to be tested ;)
May 12th, 2019, 12:03 pm
Having taken my spare box apart a good while ago, I'm just reassembling it on my coffee table in my lounge. I love being single. :lol:
I have progressed to the stage where I have to keep recovering the springs from behind the sofa. :lol:
May 12th, 2019, 12:24 pm
First attempted.
https://uk.rs-online.com/web/p/machine- ... s/2244476/
Get a reamer, and make the hole to 4.96-4.98mm with that. A little tapered reamer, and you can have whatever size ever works with...
May 12th, 2019, 2:18 pm
