View unanswered posts | View active topics It is currently June 19th, 2026, 6:38 am
Reply to topic  [ 200 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19, 20  Next
 Snetterton 24 Hour
Post Re: Snetterton 24 Hour
I'm sure there'll be pleny of cake for you Ken, if you work for Lumaca I2F next season ;) :lol:
August 24th, 2010, 11:27 pm
2CViking wrote:
Great stuff
May I ask what happend to the wheel bearing?
i think they put it in the skip
( there was a few bearing failures this year, our main competitor had to change a bearing with 2 hour to go . There is a fair bit of wheel to wheel contact during the race we lost 3 rims, gadgets car rolled in a spectacular 3 full turns in the air holyywood style after sliding sideways in to the kerbs, never a good move for wheelbearing longevity )
August 25th, 2010, 8:06 am
I had worries about ours after the damage, I was surprised to find that after the impact all the right front wheelnuts were loose, which they weren't before. We also noticed (at the end) the rose joint for the Belgian arm that side was unattached one end, I'm assuming the crash damage caused that too. I'm interested to see what the damage to the rack is, as our drivers reported a lot of play in the steering after it's accident.
Ken, thanks for your advice, I'd just got up and was in no fit state for anything when that happened, it would have probably taken much longer to sort out if you'd not been there. We definately owe you a piece of cake.
August 25th, 2010, 8:15 am
It would be interesting to know the 3 winning cars motor config. and what gear box they are running. Any info on that?
Would love to race one day.
August 25th, 2010, 10:16 am
Max wrote:
You should bring the racer down Simon.
Cool Picture 8-)
Seen super2cv this morning Max?
August 25th, 2010, 10:29 am
Xmas wrote:
Cool Picture 8-)
Etienne is currently sat in the same room as me. :lol: Hes stopping here until the International.
August 25th, 2010, 12:00 pm
Crikey, Lumaca... One lap in the first hour? What happened?
Oh - and Max... Tell Etienne I've got Super2cv on my RSS feed - it's absolutely TOP WORK!
August 25th, 2010, 5:03 pm
http://www.2cvracing.org.uk/technical/the-24-hour-race
i think they have to use the standard gearbox
August 25th, 2010, 5:15 pm
I don't know where you're looking, but the timing classification for the first hour says we did 22 laps. We had to change a carb and inlet and then adjust the float level. We had fuelling issues that didn't show themselves in practice, qualifying or warm up, but reared it's ugly head after two laps. We misdiagnosed it as fuel starvation when in effect it was actually overfuelling, and our adjustment on the engine mounts merely served to make it worse. Thankfully, it was only in the pits for a few laps and then sorted. The only other problems we had were boiling brake fluid at 3:45am which I suspect was down to the handbrake being left on after a pitstop, and the silencer became holed at some point which we welded a patch over and carried on. We also had to change a tyre because the c2cvrc dictate we must use toyos. Which are shit.
August 25th, 2010, 5:18 pm
at an educated guess:-
standard 2cv6 box -well thats essential
standard 2cv engine block and crank, 9:1 pistons,2;1 tuned exhaust, standard M28 inlet manifold with solex for Alex and rentboys(some may have used the club webber kit some started on webbers but changed), shortened barrels, club camshaft',single piece stainless inlet valves, un filled heads( i think) and (theoretically) standard tappets, double springs (probably), lumenition and harley type coil.
when the webbers got going they seem fast tho prone to water ingestion when it rains and run very thirsty.
food for thought?
you gonna come play soon?
standard car?
August 25th, 2010, 5:19 pm
